Window.open called twice for oauth login
(Fred Kelly) #1
Hola,
We’ve noticed since upgrading to v1.0.2 that when a user clicks sign in two new ‘externalLogin’ dialogs are opened on top of another.
It seems that this is being caused by this change: FIX: dispatch correct modal on auto login · discourse/discourse@e16dd96 · GitHub
Specifically it seems lines 51-53 are triggering two windows (perhaps because both autoLogin (which contains calls to showModal) and showModal itself are called?).
I’m assuming this is probably a nuance relating to our particular configuration, rather than a general bug. Does anyone know what might be happening here?
Much appreciated! :slight_smile:
(Sam Saffron) #2
Can you expand on your particular config, and perhaps give me a repro?
(Fred Kelly) #3
Hi Sam,
We are using our own custom auth provider (subclass of OmniAuth::Strategies::OAuth2) with local logins disabled (this is the only overridden login setting).
Are there any specific configuration values that would help you diagnose?
Thanks
(Sam Saffron) #4
Can this be reproduced with any other strategy ? Perhaps only enable GitHub etc? Do you have a local dev setup?
(Fred Kelly) #5
I will try using Github and see if the same happens.
Yes I am running locally; you can see the error in production at http://community.bitnami.com/
(Fred Kelly) #6
Turns out this was a patch we’d added in the past calling autoLogin() a second time :blush: – thanks for your help.
(Jeff Atwood) #7
