Working with plugin_store_rows with API, Possible?
(Hosein Naseri) #1
Is there any way to get and set plugin_store_rows values with an API call?
(Rafael dos Santos Silva) #2
A PUT to https://example.com/u/USERNAME.json with form data in the format custom_fields[USER_FIELD_NAME] works.
(Hosein Naseri) #3
No I’m not talking about user custom field. I’m talking about plugin_store_rows. As far as I know its consist of the following parameters:
id, plugin_name, key, type_name, value
(Rafael dos Santos Silva) #4
Oh sorry, misread it.
I believe you will need to create a controller in a plugin that accepts your changes
(Hosein Naseri) #5
Thank you. Can you explain a little bit about this controller? How is it look like. Or is there a tutorial I can read?
(Blake Erickson) #6
A controller is a part of the MVC pattern that rails uses.
What are you trying to accomplish? You might need to modify the plugin that is storing the data in the plugin_store_rows table and add a controller to that plugin so that you can make api calls to it rather than a new plugin.
I would look at examples in other plugins (like the discourse-voting plugin) to learn how to add a controller to a plugin.
Another solution might be do use the data explorer plugin to write a query to the plugin_store_rows table. And then you can call that saved query through the api.
