WP-Discourse display comments
(John Arce) #1
I just installed the wp-discourse plugin. but the comments thread is not displaying on my wordpress site.
Screenshot:
I want the same setup of codinghorror.
Any tips?
(Ben T) #2
I believe there is a configuration flag for the number of comments to display. Try setting it to a higher number.
(John Arce) #3
Can you check my settings?
(Ben T) #4
I don’t have a live install to check on, but you may want to set the Bypass trust level score to 0 as well if you want all comments to show up.
You can see what would be pulled by going to a topic on your discourse install, removing the traling number and replacing it with /wordpress.json?best=20. Here is this thread for example.
(John Arce) #5
I tried changing Bypass trust level score to 0 but still getting same issue.
Anyone using the wp-discourse? let me know your thoughts on this
(Jeff Atwood) #6
Did you set up the API key? It’s the 2nd setting from the top for WP-Discourse.
Get it from the /admin panel, API section.
(John Arce) #7
After I regenerate my API key then save it again. Finally it’s working.
(Rhinodf) #8
excuse my ignorance guys. The answer to this is likely to be answered somewhere else here but im having the same problem.
I have tried everything in this thread to no avail… also slightly unrelated but my header has changed since moving my installation
(Rhinodf) #9
Found the problem! Was because I didn’t choose a correlating user name in Wordpress
