Wrong behavior of advanced search + category slug
(Pad Pors) #1
sorry the images are with Persian words. if you note at the red circles, I hope you can see the wrong behavior.
if I go to the search page and I search a word, I’ll find some entries for it:
if I want to do the same search in a specific category using the advanced search it gave me wrong results:
as you can note it didn’t find anything. though in the first image, the first entry is from the same category selected in the second image.
if you go to the category page, and search in the category for the word, you will see the correct result:
(Pad Pors) #2
It doesn’t happen here in meta, perhaps it’s because of the Persian name of the category and its difference with the category slug in our case.
that may also be the reason when I searched from the category page, the search uses the category ID instead of its slug.
