Wrong French translation for the category page title
(Camille Roux) #1
Currently, category title in the French locale is “{title} Sujets” like in English, but it’s not correct. It should something like “Sujets de la catégorie {title}”.
I can’t found the locale to change it. Anyone can help me?
(Régis Hanol) #2
I’m not sure I understand what you mean. Which title?
Also, if you want to propose an update on the French translation, you’re more than welcome to do so on transifex :wink:
(Camille Roux) #3
This one :
I can’t found it on transifex.
(Camille Roux) #4
I found an other mistake here : discourse/server.fr.yml at master · discourse/discourse · GitHub
We should update “communautée” to “communauté” but I can’t find it also on transifex.
(Neil Lalonde) #5
Searching on Transifex is a little more complicated than other searches.
  1. Choose a file (in this case, I found it in server.yml)
  2. In the search field, choose what type of search it is. In this case, it’s “Translation text”.
  3. Enter the text to search for.
I found uses of that translation there.
(Sebastien Miquerolle) #6
Thanks for the correction :thumbsup:
(Camille Roux) #7
Thanks to @zogstrip, everything seems ok, except the category page title. I can’t find the locale for it. It looks like they just concatenate the category title with the translation of “topic”.
I can’t found where is it in the code. Can something can check this? Thanks!
(Régis Hanol) #8
There?
https://github.com/discourse/discourse/pull/2307/files
(Camille Roux) #9
Thanks! I don’t know if it’s the title used for the category page, but it’s the same problem and should be fix :slight_smile:
