X (cross) on invite
Hello,
When you write something in invite the message is like this:
However, it should be like this:
This only happens with forums on beta9. Also, the cross cannot even be pressed so perhaps it could be removed.
Can you please post the exact steps that you’re using to invite that person?
Sorry I described this wrong.
When you invite you must write a valid username as you know. However, to get this issue you must type something that is not a username. A user tried to invite staff in a topic but you can’t do that. You then press invite and the message which is normal appears but with a weird white box.
