rsmithlal
(Robert Smith)
April 18, 2024, 1:18am
185
I’ve run into an issue. Perhaps it’s an edge case. I set up one of my categories to use ActivityPub, but it’s not accessible on other platforms like Mastodon, and posts are not being federated because I can’t access and follow the category.
I think it might be an issue due to the capital “E” in the handle. Events@bayofislands.community
I have another category federated that works fine. You can see it in action at
The Bay of Islands Community is a vibrant, volunteer-run platform fostering connections and collaboration among residents of Newfoundland's scenic West Coast, empowering them with local news, resources, and opportunities for communal engagement and...
Any suggestions to get this to work without creating a whole new events category? Can I modify one or more records in the DB to update the username for the category?
I’m also noticing that the URL to follow a category is not working in Mastodon: Log in - Mastodon Newfoundland and Labrador
angus
(Angus McLeod)
April 18, 2024, 12:22pm
186
Thanks for the report. Change the E to a lowercase and it’ll work
I’ll fix this issue (i.e. handles with uppercase letters) soon.
Jagster
(Jakke Lehtonen)
April 18, 2024, 12:24pm
187
Can we delete followers? I have few actors who came from now deleted instance and I would like to clean up places
angus
(Angus McLeod)
188
A good request, I’ll add that soon too.
angus
(Angus McLeod)
April 18, 2024, 1:04pm
189
I’m not sure this is a capitalization issue actually. Could I confirm the following:
you’re running the latest version of Discourse; and
you’re running the latest version of the ActivityPub plugin.
Lhc_fl
(Linca)
April 21, 2024, 3:36am
190
I realized one thing: the user created by ActivityPub Plugin does not have any group assigned to it, and does not have any emails.
Is it possible to assign custom groups to users created by ActivityPub Plugin?
Lhc_fl
(Linca)
April 21, 2024, 3:41am
191
This also resulted in a bug where if the category was set to TL0 could post (readonly for everyone
), AP users may not post as they did not have this permission
Lhc_fl
(Linca)
April 21, 2024, 5:25am
192
There is also a bug here. If the SiteSettings.selectable_avatars_mode
is set, even it was set to everyone
, it will cause the AP user to lack avatars.
angus
(Angus McLeod)
April 23, 2024, 7:33am
193
Jakke Lehtonen:
This is ready to go, and is up for review after Tag Actors is merged.
discourse:main
← angusmcleod:admin_remove_followers
opened 11:52AM - 20 Apr 24 UTC
@pmusaraj Once https://github.com/discourse/discourse-activity-pub/pull/84 is me… rged, this is next (this is already based on the tags branch)
See further: https://meta.discourse.org/t/activitypub-plugin/266794/187?u=angus
Not yet. They’re staged users, so there’s a few limitations there. Perhaps a little further down the track.
Thanks for this report. I’ll take a closer look at this case soon. For now, you can set the posting permissions to everyone
and it’ll work.
Thanks for this report too. I’ll take a closer look at this case soon too.
scavin
(scavin)
April 24, 2024, 3:11am
194
Hi I’m having this problem with pubilsh “no recipients”, How do I troubleshoot the problem?
[Discourse Activity Pub] https://meta.appinn.net/ap/actor/b04930460474d895289ae0cd3c2ae719 failed to schedule https://meta.appinn.net/ap/activity/2ad9bfcc78a9df49efa7b6e9bda454da for delivery: no recipients
Logs:
Message
Backtrace
/var/www/discourse/plugins/discourse-activity-pub/lib/discourse_activity_pub/delivery_handler.rb:93:in `log_failure'
/var/www/discourse/plugins/discourse-activity-pub/lib/discourse_activity_pub/delivery_handler.rb:35:in `can_deliver?'
/var/www/discourse/plugins/discourse-activity-pub/lib/discourse_activity_pub/delivery_handler.rb:13:in `perform'
/var/www/discourse/plugins/discourse-activity-pub/lib/discourse_activity_pub/delivery_handler.rb:27:in `perform'
/var/www/discourse/plugins/discourse-activity-pub/app/models/concerns/discourse_activity_pub/ap/model_callbacks.rb:140:in `activity_pub_deliver_activity'
/var/www/discourse/plugins/discourse-activity-pub/app/models/concerns/discourse_activity_pub/ap/model_callbacks.rb:38:in `perform_activity_pub_activity'
/var/www/discourse/plugins/discourse-activity-pub/plugin.rb:478:in `block (2 levels) in activate!'
/var/www/discourse/lib/plugin/instance.rb:354:in `public_send'
/var/www/discourse/lib/plugin/instance.rb:354:in `block (2 levels) in add_to_class'
/var/www/discourse/plugins/discourse-activity-pub/plugin.rb:486:in `block (2 levels) in activate!'
/var/www/discourse/plugins/discourse-activity-pub/app/controllers/discourse_activity_pub/post_controller.rb:17:in `schedule'
actionpack-7.0.8.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack-7.0.8.1/lib/abstract_controller/base.rb:215:in `process_action'
actionpack-7.0.8.1/lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack-7.0.8.1/lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:118:in `block in run_callbacks'
/var/www/discourse/app/controllers/application_controller.rb:423:in `block in with_resolved_locale'
i18n-1.14.4/lib/i18n.rb:322:in `with_locale'
/var/www/discourse/app/controllers/application_controller.rb:423:in `with_resolved_locale'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack-7.0.8.1/lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack-7.0.8.1/lib/action_controller/metal/rescue.rb:23:in `process_action'
actionpack-7.0.8.1/lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport-7.0.8.1/lib/active_support/notifications.rb:206:in `block in instrument'
activesupport-7.0.8.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport-7.0.8.1/lib/active_support/notifications.rb:206:in `instrument'
actionpack-7.0.8.1/lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack-7.0.8.1/lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord-7.0.8.1/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack-7.0.8.1/lib/abstract_controller/base.rb:151:in `process'
actionview-7.0.8.1/lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler-3.3.1/lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionpack-7.0.8.1/lib/action_controller/metal.rb:188:in `dispatch'
actionpack-7.0.8.1/lib/action_controller/metal.rb:251:in `dispatch'
actionpack-7.0.8.1/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack-7.0.8.1/lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack-7.0.8.1/lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack-7.0.8.1/lib/action_dispatch/journey/router.rb:32:in `each'
actionpack-7.0.8.1/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-7.0.8.1/lib/action_dispatch/routing/route_set.rb:852:in `call'
railties-7.0.8.1/lib/rails/engine.rb:530:in `call'
railties-7.0.8.1/lib/rails/railtie.rb:226:in `public_send'
railties-7.0.8.1/lib/rails/railtie.rb:226:in `method_missing'
actionpack-7.0.8.1/lib/action_dispatch/routing/mapper.rb:19:in `block in <class:Constraints>'
actionpack-7.0.8.1/lib/action_dispatch/routing/mapper.rb:48:in `serve'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack-2.2.9/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.9/lib/rack/conditional_get.rb:40:in `call'
rack-2.2.9/lib/rack/head.rb:12:in `call'
actionpack-7.0.8.1/lib/action_dispatch/http/permissions_policy.rb:38:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:393:in `call'
/var/www/discourse/lib/middleware/csp_script_nonce_injector.rb:12:in `call'
/var/www/discourse/config/initializers/008-rack-cors.rb:26:in `call'
rack-2.2.9/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.9/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack-7.0.8.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/show_exceptions.rb:29:in `call'
logster-2.19.1/lib/logster/middleware/reporter.rb:40:in `call'
railties-7.0.8.1/lib/rails/rack/logger.rb:40:in `call_app'
railties-7.0.8.1/lib/rails/rack/logger.rb:27:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:20:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/request_id.rb:26:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:24:in `call'
rack-2.2.9/lib/rack/method_override.rb:24:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/executor.rb:14:in `call'
rack-2.2.9/lib/rack/sendfile.rb:110:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler-3.3.1/lib/mini_profiler.rb:191:in `call'
message_bus-4.3.8/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:237:in `call'
rack-2.2.9/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.9/lib/rack/urlmap.rb:58:in `each'
rack-2.2.9/lib/rack/urlmap.rb:58:in `call'
unicorn-6.1.0/lib/unicorn/http_server.rb:634:in `process_client'
unicorn-6.1.0/lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn-6.1.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
Env
HTTP HOSTS: meta.appinn.net
nathank
(Nathan Kershaw)
April 24, 2024, 3:24am
195
I think you need someone (or some ‘actor’) to follow the Category. See this:
Most likely because there is no-one following your category. If you turn on the site setting activity_pub_verbose_logging and look in your logs you will probably see a message that looks like this
I’m definitely going to put a “reason” in that modal as this has come up a few times now! Follow your category on Mastodon, and then create a new topic.
**edit or perhaps I will just change it to “published” in that scenario, as it does in fact add the activity to the outbox. It just doesn’t send it…
scavin
(scavin)
April 24, 2024, 3:29am
196
But when I follow this Category using mastodon.social:
[Discourse Activity Pub] POST request received by https://meta.appinn.net/ap/actor/b04930460474d895289ae0cd3c2ae719/inbox failed: 401 Actor not found for key https://mastodon.social/users/Cosmeticclinic#main-key
Is this a bug? (Invalid date
