AI module does not take proxy settings
Hello,
i have an intranet installation and i use the AI extension.
I have set up configuration from docker so that proxy settings are passed to my container when it runs. I can check for instance Discourse update and they appear and i can apply them. So from Discourse the proxy settings are correctly passed otherwise it should not work.
The problem is that requests from the AI module are failing and i feel that this module does not take at all my proxy settings. All request does not pass the proxy and fails …
As anyone one experiencing this problem ?
Any help would be great !!
Thanks.
Are you running the models yourself on the intranet in another server? Or are those calls to third parties outside your network? If so, which sites?
Mainely inside on an intranet server …
If often have these errors :
  • Job exception: FinalDestination: all resolved IPs were disallowed
  • Job exception: FinalDestination: lookup failed
