Trouble with Email Verification After Discourse Installation
Hello,
I’ve installed Discourse on my VPS using Docker, and everything seems to be working fine except for one crucial feature - email verification. Here’s the issue I’m encountering:
After successfully setting up Discourse on my domain (forum.askseotools.com), I proceeded to create an admin account. However, when I entered my email address for verification, I never received the verification email.
I’m running Discourse on Ubuntu 20.04 LTS 64 Bit with aapanel.
please check app.yml file.
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  ## Uncomment the next line to enable the IPv6 listener
  #- "templates/web.ipv6.template.yml"
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "3001:80"   # http
  #- "443:443" # https
params:
  #db_shared_buffers: "256MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  #UNICORN_WORKERS: 3
  ## Required. Discourse will not work with a bare IP number.
  DISCOURSE_HOSTNAME: 'forum.askseotools.com'
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'ianasystems@gmail.com,ianasystems@gmail.com'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: mail.askseotools.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: forum@askseotools.com
  DISCOURSE_SMTP_PASSWORD:
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  #DISCOURSE_SMTP_DOMAIN: discourse.example.com    # (required by some providers)
  #DISCOURSE_NOTIFICATION_EMAIL: noreply@discourse.example.com    # (address to send notifications from)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP address key for IP address lookup
  ## see https://meta.discourse.org/t/-/137387/23 for details
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
  - exec: rails r "SiteSetting.notification_email='forum@askseotools.com'"
please update.
Thanks.
This section looks grossly misconfigured to me.
There is no SMTP password, notification email or SMTP domain. You will need all three of those for emails to work and might also need to check your smtp server to confirm if it is being blacklisted by other email providers.
Self hosted smtp is the easiest way to get your emails rejected if not configured and maintained correctly.
See Troubleshoot email on a new Discourse install
Thank you for your prompt response. I appreciate your insights.
I’ve made adjustments to the SMTP password in my app.yml file before sharing it here for support.
I’ll address the commented-out lines for #DISCOURSE_SMTP_DOMAIN and #DISCOURSE_NOTIFICATION_EMAIL to ensure their configuration.
Regarding the SMTP setup, I’ve conducted tests with my self-hosted SMTP, and it’s functioning correctly. I’ve successfully sent and received emails from Gmail via the mail app in aapanel.
Let me know if there are any other aspects I should address or if you require further information.
Thank you again for your assistance.
Please check.
./discourse-doctor
Just like the error message you showed suggests.
Looks like the cert for your smtp server is broken.
https://ssl-tools.net/mailservers/mail.askseotools.com
Yes,
you’re right.
How to fix? please let me know.
Thanks.
Ask the people who run the mail server to fix it.
Thank you very much, Pfaffman, for bringing attention to the SSL certificate problem. I’ve resolved the SSL certificate issue, and now email verification is functioning properly. I’m receiving the email verifications without any problems.
