Replace a string in all posts
:bookmark: This guide explains how to replace a string in all posts within a Discourse instance.
:person_raising_hand: Required user level: System Administrator
:warning: Console Access Required
Want to replace a string in all the posts on a site? Let’s get started!
:warning: WARNING: We strongly recommend you take a full backup before proceeding, and make sure your string replacement is specific enough to affect only the places you want it to. If this string replacement goes wrong, every post on your site will look broken!
Access your site
Start by accessing your Discourse instance via SSH and entering the Docker container:
cd /var/discourse
./launcher enter app
Performing string replacements
Basic case-sensitive replacement
To replace a string, use the following command. Replace find with the string to locate and replace with the desired substitution:
rake 'posts:remap[find,replace]'
Example results:
find —> replace
Find —> Find
FIND —> FIND
finders keepers —> replaceers keepers
finding —> replaceing
This method can be useful for tasks such as replacing emojis:
rake 'posts:remap[:slightly_smiling:,:slight_smile:]'
The above command will replace all occurrences of :slightly_smiling: with :slight_smile:.
Case-insensitive replacement
For replacements that ignore case sensitivity use:
rake 'posts:remap[find,replace,string,true]'
Example results:
find —> replace
Find —> replace
FIND —> replace
Regex replacement
For advanced replacements with regex, format the command accordingly:
rake 'posts:remap[(?<!\\w)(?=\\w)find(?<=\\w)(?!\\w),replace,regex]'
Example results:
replace —> replace
Find —> Find
FIND —> FIND
finders keepers —> finders keepers
finding —> finding
Deleting words or strings
To completely remove a word or string, apply these commands:
Basic case-sensitive deletion
rake 'posts:delete_word[word-to-delete]'
Case-insensitive deletion
rake 'posts:delete_word[word-to-delete,string,true]'
Regex deletion
rake 'posts:delete_word[\\[color=#[0-9a-fA-F]{3,6}\\],regex]'
Batch processing to search and replace in all posts
Global Replace across database
[Announce] Search & replace / batch process Discourse posts
How do I change the legacy CDN URLs of images in posts?
How to automatically replace a double exclamation point when a message is saved?
Administrative Bulk Operations
Updating image URL's after a domain change
Replacing content in multiple topics with Regex?
Forum Link Checker
Remove BBCode and convert to Markdown
Tool to remove email addresses from posts
Bulk replacement in translated strings?
Youtube embeds missing
Fix quotes after phpBB import
Is there a way to easily replace the word "Topic" everywhere on my site at once
Shouldn't users be able to delete their accounts whenever they want?
Localised inline date/time
Watched words - replace link/url works in test but not in post
Permalink question (rewriting/redirecting old gallery contents)
Hosted to self-hosted migration: past uploads still reference discourse infra
How to fix formatting issues? - markdown badly migrated to HTML
How to run rake posts:remap with domain?
Migrate a phpBB3 forum to Discourse
Discourse Doc Categories
What is rebaking and is it necessary when moving a server?
Discourse s3 backup folder
Pin more than one topic globally
After migrating from XenForo to Discourse
Search and Replace a text string in the post database
Trouble with `discourse remap` remapping `topic_links url`
CommonMark testing started here!
Remove images from PMs that have been inactive for >1 year
Masonry Image Gallery
Redirect Article- possible?
(Superseded) Set up backup and image uploads to DigitalOcean Spaces
Upload links broken after S3 bucket change
How to search and replace URL instances throughout topics?
Enable a CDN for your Discourse
How do I move my s3 upload bucket from one provider to another?
Imgur images broken
Move from BackBlaze B2 to Digital Ocean Spaces
What's the fastest way to replace strings with multiple regexes in 1 million posts?
Too many user emails domains not working lead to mailgun domain disabled: what to do?
Renaming uploaded files
After rebuilding, avatar photos are missing
The change of from "tags" to "tag" in its URL affects my Discourse since they are linked in many posts. How can I automatically change them?
Switch from TAGS to TAG broke links in posts and "Delete Unused Tags"
How would I do this for just the topics in a single category?
My use case is an imported RSS feed which annoyingly displays a ? instead of a '. And as the feed is a news feed with lots of quotations, this is a problem!
You’d do it from rails, and it’ll be hard because posts don’t belong to categories, topics do. Sounds like you need a plugin if this is a continual issue. You could be clever with a join or just loop like
Topics.where(category_id: 123).each do |t|
  posts.where(topic_id: t, post_number: 1).each do |p|
    if p.raw.match("?")
        p.raw.gsub!("?","'")
        p.save
If it’s not only in post_number: , don’t include that.
If it’s not a huge number of posts, then this is probably good enough, if it works at all.
Thanks Jay! That would do the trick nicely.
I do need to troubleshoot it properly and see if there is an upstream fix. Or I might need to bolt something onto the RSS Polling Plugin which is a bit of a tricky beast!
Just a guess, but are you seeing any other issues with posts created from the RSS feed? Are the ? characters present when you view the feed’s source? I’m wondering if what you are running into is an encoding issue.
Yeah, I’m just looking at this now. The ? are in there every time there is an unusual character, so it is a problem at the RSS source end. It turns out that ' is just the most common one, but it is also happening for ā, ", and one or two others.
Unfortunately the software company involved isn’t quite as responsive as the Discourse team :kissing_heart:! Wish me luck.
That’s what I was suspecting too. It might be as simple as better detecting the right encoding.
Any guidance to replace as below please?
[member=12345] → @
I used this example which works for replacing a URL. However, it’s not working for phrases.
Example:
rake posts:remap["I Don't Want This Phrase","But I Do Want This One","string",true]
I keep getting this error:
ERROR: Expecting rake posts:remap['find','replace',type] where type is string or regex
I tried it with the single quotes as shown in the error message as well, but no dice. I even tried by placing dashes between the words like in the delete word example. That gave me the same error.
Any advice?
I’m afraid that if you need to do something with quotes it’s best to do it in rails. With the rake task, you’ve got to deal with both bash and rails to escape. You might be able to use a bunch of backslashes (that also need to be escaped), but probably not.
Have a look at the rails example that I have above and see if that makes sense. I’ll to add something to the OP next time I have a laptop.
Thanks for the response. That looks over my head, I can sure learn though.
It sounds like the quotes in the text string is what caused my issue…
My purpose, I find myself changing titles and urls to my blog, so I like to go back to the forum and update those links, the titles and urls as well. I can see this being a semi-regular task when I’m working on SEO. Any more details would be fantastic.
There must be something I’m not understanding here. I’m trying to replace occurrences of :THUMBS-UP: with :+1: across almost 3M posts (including PMs). I ran:
rake posts:remap[":THUMBS-UP:",":+1:"]
And after about 50 minutes of ................. it returned 40000 posts remapped! This seems like a suspiciously even number. I did find some occurrences that were replaced with :+1: in both recent posts and posts from many years ago, but there are also a ton of :THUMBS-UP: even in the same topic threads that also have some successful :+1: replacements.
That sure seems a bit weird. Did you try to remap again?
You can also easily return the number of posts that still contains :THUMBS-UP: using data-explorer if this info can be of some use.
Yeah, it’s weird. I did try running the same command two three more times, and each time it remapped 333 more posts… :question:
In the log it’s showing a bunch of supposed replacements, except that when I reload the page and inspect the actual post it remains unchanged:
This seemed to me like a caching issue, so I did a redis-cli flushall and hard-reloaded Discourse, but still no change in the posts that were reported as edited in the log.
And also in the error log a bunch of messages like this:
This should be fine… but one of the problems is that it looks like you can quote other things such as commas, but you can’t since the quotes are consumed by the shell, not by the rake parser.
e.g.:
→ rake posts:remap["a,b","a+b"]
And the brackets should be quoted since they’re shell metachars themselves. You won’t even be able to run the command with a file called posts:remapa in the directory (unlikely as this may be) or with failglob set.
I think we should change these commands - they’re misleading in the sense that they look like you’re quoting the strings being replaced, but we really aren’t. The quotes are consumed by the shell; rails never sees them. No reason to even have the quotes, and if rails does see them they’ll be part of the string:
→ rake 'posts:remap["find","replace"]'
Are you sure you want to replace all string occurrences of '"find"' with '"replace"'? (Y/n)
Some more examples including how to deal with things like commas are:
rake $'posts:remap[string with a quote\',string without a quote]'
rake 'posts:remap[a\, b,a+b]'
though, quirkily, this works:
→ rake 'posts:remap[string with a bracket] either quoted\] or not,string without a bracket]'
Are you sure you want to replace all string occurrences of 'string with a bracket] either quoted] or not' with 'string without a bracket'? (Y/n)
Is it possible the raw is changed, but the (new) post is not yet baked?
I thought about that too, but no, I hit the edit button on those posts and the raw is unchanged. And on the successful replacements the new emoji appears without a rebake.
So I’m trying to replace 600+ instances of an imported YouTube links, but it seems to only work when it’s on a line by itself.
So I need to insert a newline before the YouTube link itself. Thankfully, I have a “replaceme” type of string that can be replaced with the newline.
Is the appropriate way to do a Ruby newline? Or a Markdown newline?
Would something like this work?
rake posts:remap["replaceme","\n",string,true]
Or do I need to escape the \n a few times?
rake posts:remap["replaceme","\\\n",string,true]
Or should I aim for the markdown newline (which is a single backslash, correct?):
rake posts:remap["replaceme","\",string,true]
I guess I’d have to escape that too?
Any guidance appreciated.
I’d do it in rails where you don’t have to worry about so many levels of quoting.
Good idea. Escaping things makes my head hurt.
I see your code above is easy enough. Something like this?
  posts.where(topic_id: t).each do |p|
    p.raw.gsub("replaceme","/")
Something like that? I assume the markdown / is better than using CR/LF or \n, or even
or whatever?
How does one run this from the shell? Just type in “rails” and then copy the code in there?
