If you have an existing website or application and you would like to encourage discussion on your Discourse forum it can be helpful to display Discourse notifications inside of your application. This guide will show you how to use the Discourse API to fetch notifications for a user and how to mark them as read.
The recommended way of using the API is to have your application make back-end requests to Discourse and then pass that data to the front-end/presentation layer of your application.
Checkout the API Documentation for info on how to use the Discourse API.
Fetching notifications for a user
To get notifications via the API you can make an authenticated GET request to the /notifications endpoint. You can either specify the username you are fetching notifications for in the Api-Username header or as a query parameter: /notifications?username=<username>.
Optional query parameters
| Parameter | Description |
username |
The username to fetch notifications for |
filter |
Filter by read state: read or unread |
filter_by_types |
Comma-separated list of notification type names to filter by (e.g. mentioned,replied) |
offset |
Offset for pagination |
limit |
Number of notifications to return (max 60) |
Example request
curl -X GET "http://localhost:8080/notifications.json?username=blake.erickson" \
-H "Api-Key: e81c4022f148c872a98fb38dac1d9619c7f5b245b42ba98fa467968bbed7551e" \
-H "Api-Username: system"
This will return the following the JSON response
"notifications": [
"id": 3,
"user_id": 5,
"external_id": null,
"notification_type": 12,
"read": true,
"high_priority": false,
"created_at": "2019-06-17T20:26:05.670Z",
"post_number": null,
"topic_id": null,
"slug": null,
"data": {
"badge_id": 41,
"badge_name": "First Emoji",
"badge_slug": "first-emoji",
"badge_title": false,
"username": "blake"
"id": 2,
"user_id": 5,
"notification_type": 6,
"read": true,
"high_priority": true,
"created_at": "2019-06-17T20:26:04.305Z",
"post_number": 1,
"topic_id": 10,
"fancy_title": "Greetings!",
"slug": "greetings",
"data": {
"topic_title": "Greetings!",
"original_post_id": 14,
"original_post_type": 1,
"original_username": "discobot",
"revision_number": null,
"display_username": "discobot"
"total_rows_notifications": 2,
"seen_notification_id": 3,
"load_more_notifications": "/notifications?offset=60&username=blake"
This returns a notification array. If you are interested in only showing unread notifications you can pass the filter=unread query parameter to have the server return only unread notifications. For example:
curl -X GET "http://localhost:8080/notifications.json?username=blake.erickson&filter=unread" \
You can visit this page for a listing of notification types. For example notification type: 12 maps to “granted_badge”.
Marking notifications as read
Now that you have fetched a user’s notifications you can mark them as read by sending a PUT request to /notifications/mark-read with the id of the notification in the request body and by specifying the username in the request header.
Example request
curl -X PUT "http://localhost:8080/notifications/mark-read" \
-H "Api-Username: blake.erickson" \
-F "id=4"
You can also leave off the notification id and it will mark all notifications for that user as read.
This will return a simple “OK” JSON response:
"success": "OK"
