בדיקת קוד אוטומטית ופורמט לפני ההתחייבויות
Discourse uses lefthook for git hooks, and bin/lint as the main CLI entry point for running the same checks manually.
If you are working in a local clone, install the hooks once:
pnpm install
pnpm lefthook install
After that, staged files will be checked automatically on git commit.
The main command: bin/lint
Use bin/lint when you want to run the repo’s configured linters yourself instead of waiting for the pre-commit hook.
Common examples:
bin/lint
bin/lint path/to/file.rb path/to/file.gjs
bin/lint --recent
bin/lint --staged
bin/lint --unstaged
bin/lint --wip
bin/lint --fix path/to/file.rb
bin/lint --fix --recent
bin/lint --fix
What each mode does
  • bin/lint: lint all supported files in the repository
  • bin/lint path/to/file ...: lint only the given files
  • bin/lint --recent: lint files changed in the last 50 commits, plus untracked files
  • bin/lint --staged: lint only staged files
  • bin/lint --unstaged: lint only unstaged files
  • bin/lint --wip: lint staged files, unstaged files, and files changed since main
  • bin/lint --fix ...: run the auto-fixers for the selected files
  • bin/lint --fix: run all available auto-fixers across the repository
  • bin/lint --verbose: print the underlying lefthook commands
When you pass explicit files, bin/lint filters them to supported lintable file types before invoking lefthook.
:information_source: Markdown files are only linted under docs/developer-guides/. Running bin/lint path/to/doc.md on any other Markdown file will report that nothing was linted.
What gets linted
The exact configuration lives in lefthook.yml. At the time of writing, bin/lint covers:
Ruby
  • **/*.{rb,rake,thor}
  • Ruby scripts under bin/**/*
  • Gemfile
Checks:
  • rubocop
  • syntax_tree (stree check)
JavaScript, GJS, CSS, and SCSS formatting
  • app/assets/stylesheets/**/*.{css,scss}
  • frontend/**/*.{js,gjs,scss,css,cjs,mjs}
  • matching plugin and theme asset files
Checks:
  • prettier/pprettier
JavaScript and GJS linting
  • frontend/**/*.{js,gjs}
  • matching plugin and theme JS files
Checks:
  • eslint (with eslint-plugin-ember’s template-* rules covering the template portion of .gjs files)
SCSS linting
  • app/assets/stylesheets/**/*.scss
  • matching plugin and theme SCSS files
Checks:
  • stylelint
YAML and locale checks
  • **/*.{yaml,yml} except config/database.yml
  • **/{client,server}.en.yml
Checks:
  • yaml-lint
  • script/i18n_lint.rb
Type checking
When you run bin/lint with no file arguments, the full-repo lint also runs:
  • pnpm lint:types
This is the Glint/TypeScript-style check for Discourse’s type information. It runs in TypeScript’s strict mode and also generates the published declarations.
:information_source: bin/lint path/to/file and the pre-commit hook do not run the full type check. Use plain bin/lint when you want the complete repo-wide lint pass.
What can be auto-fixed
bin/lint --fix can automatically fix a lot of issues, but not all of them.
Auto-fix is configured for:
  • prettier --write
  • eslint --fix
  • stylelint --fix
  • rubocop -A
  • syntax_tree (stree write)
In practice, that means --fix can reformat and rewrite:
  • Ruby
  • JavaScript / GJS
  • CSS / SCSS
These checks are not auto-fixed by bin/lint --fix:
  • YAML syntax validation
  • i18n linting for client.en.yml / server.en.yml
  • Glint/type checking
Relationship to git hooks
The pre-commit hook uses the same lefthook configuration as bin/lint, but it runs only against staged files.
That means:
  • a commit can fail because staged files do not pass linting
  • bin/lint --staged is the closest manual equivalent to the pre-commit hook
  • bin/lint --fix --staged is a good way to repair exactly what you are about to commit
Practical workflow
For day-to-day development, these are the most useful commands:
# Before committing a couple of changed files
bin/lint --fix path/to/file1.rb path/to/file2.gjs
# Check exactly what the pre-commit hook will check
bin/lint --staged
# Clean up all current in-progress work
bin/lint --fix --wip
# Run the full repo lint suite, including type checks
bin/lint
This document is version controlled - suggest changes on github.
11 לייקים
7 posts were split to a new topic: Debugging linting on Discourse
