Tag Icons working with tag groups
The discussion revolves around the Tag Icons plugin and its potential expansion to support tag groups. fellowshipforums expresses enthusiasm for the plugin and suggests extending it to work with tag groups, allowing multiple tags within a group to share a specific icon. pmusaraj explains that this feature is not currently available due to technical limitations. AstonJ and tobiaseigen echo the request, highlighting the need for efficiency when managing a large number of tags. pmusaraj acknowledges the idea as a nice-to-have but lacks the time to implement it. Moin shares a workaround using Data Explorer to generate a configuration string for tag groups, streamlining the process of assigning icons to multiple tags.
Wow, this is awesome!
Can this be expanded to work with tag groups? (All tags within a specific tag group would get a specific icon)
At this time, no, it can’t work with tag groups because the component doesn’t have access to the makeup of tag groups.
Okay. We have a large number of tags (over 200) but will only require 3 or 4 different icons.
Is there a way we could assign one icon for multiple tags, without having a separate row for each tag?
Let me know if this makes sense
Thanks!
No, there is no way of doing that right now.
Great plugin!
I agree with @fellowshipforums that being able to specify tag groups would be really nice. So you could have a tag group for cars, another for bikes, another for boats, etc, then each from those would get their respective icons. Otherwise we would have to manually set up potentially hundreds of tag icons manually…
The tag groups feature is a nice-to-have for sure, it is a bit tricky and currently I don’t have the time to work on it.
I just installed this lovely plugin and came here to add just this bit of feedback. :wink:
I can see it being tricky to implement though, not even knowing the technical issues. For example, I have tag groups for years, people, places etc that all sensibly could be given the same icon and color, but then also have other specific tags that will want their own specific icon and color.
As long as this feature is not available, I have found a workaround that allows me to configure the icons for all tags in a tag group more quickly. I use Data Explorer to generate a string, which I then simply paste into the settings field of the component.
The query I use to generate the configuration:
--[params]
-- string :tag_group_name
-- string :icon
-- string :color
WITH selected_group AS (
  SELECT id FROM tag_groups WHERE name = :tag_group_name
tag_ids AS (
  SELECT tag_id
  FROM tag_group_memberships
  WHERE tag_group_id = (SELECT id FROM selected_group)
tag_names AS (
  SELECT name
  FROM tags
  WHERE id IN (SELECT tag_id FROM tag_ids)
SELECT string_agg(name || ',' || :icon || ',' || :color, '|') AS tag_icon_config
FROM tag_names
