Template for replies
I want the template already added to the reply window when user click on reply .
Can anyone pls tell how to achieve this
Any help would be appreciated
I’m afraid this is not currently possible, though I have recategorised the other topic you posted on as a Feature request. :+1:
Jam if the replies are only to the Op Post. Could they maybe create a url to pre-generate the reply with the template of sorts?
Still would be maybe a bit of pain though.
@Jaskaran this component alternatively might help somewhat as it allows you to change the watermark text when creating a post/reply.
This component can help give guidance on replying.
