שימוש ב-AI ליצירת עטיפת קוד bbcode להסתרת תוכן
סיכום מבוסס בינה מלאכותית
In a Dev discussion titled Using AI to create Hide content bbcode wrapper, Heliosurge shares AI-generated code for a BBCode wrapper and theme component to hide content based on user group membership. The Ruby BBCode parser wraps content in a div with group data, while JavaScript checks group membership and hides content if needed. However, Heliosurge encounters an error when implementing the JS (import syntax issue) and seeks guidance on placement and fixes. pfaffman notes that hidden content remains accessible via /posts/123/raw, making it unsuitable for security. Heliosurge references a broken existing component and links to a related topic [4]. pfaffman suggests using CSS with group-based classes or custom fields like user notes, while merefield confirms true security requires a plugin modifying the API, not a theme component. Heliosurge clarifies the use case is non-security-focused (e.g., RPG character sheets visible to players and DMs) and acknowledges client-side solutions are inherently bypassable (e.g., disabling JS, safe mode). Lilly confirms safe mode can be restricted to Staff/Admin, preventing regular users from bypassing theme-based hiding.
Using generic bbcode wrapper create theme component that hides content if not in group string variable
Show drafts
Creating a Generic BBCode Wrapper and Theme Component
Understanding the Requirements
Based on your request, we’ll create:
A generic BBCode wrapper that can accept custom attributes.
A theme component that hides content based on a group string variable passed to the BBCode wrapper.
Implementing the BBCode Wrapper
We’ll create a BBCode wrapper that can accept arbitrary attributes. These attributes will be passed to the theme component for evaluation.
Ruby
# config/initializers/bbcode.rb
Discourse::Plugins::BBCode.add_parser(:hide_if_not_in_group) do |tag, content|
  attributes = tag.attributes || {}
  "<div class='hide-if-not-in-group' data-group-names='#{attributes[:groups]}'>#{content}</div>"
Use code with caution.
Creating the Theme Component
The theme component will check if the current user belongs to any of the groups specified in the data-group-names attribute. If not, it will hide the content.
JavaScript
// app/assets/javascripts/discourse/components/hide-if-not-in-group.js
import Component from 'discourse/components/component';
export default Component.extend({
  tagName: 'div',
  classNames: ['hide-if-not-in-group'],
  didInsertElement() {
    const currentUserId = Discourse.currentUser.id;
    const groupNames = this.element.dataset.groupNames.split(',');
    // Function to check if user is in any of the specified groups
    const userIsInAnyGroup = (userId, groupNames) => {
      // Replace this with your logic to check user group membership
      // For example, using Discourse's API or custom logic
      return groupNames.some(groupName => {
        // Check if user is in the group named `groupName`
        // Return true if the user is in the group, otherwise false
    if (!userIsInAnyGroup(currentUserId, groupNames)) {
      this.element.style.display = 'none';
Using the BBCode
You can use the BBCode like this:
[hide_if_not_in_group groups="staff,moderators"]
This content is hidden for users who are not staff or moderators.
[/hide_if_not_in_group]
Important Considerations
Group membership check: Replace the placeholder logic for checking user group membership with your actual implementation. You might need to use Discourse’s API or custom logic to determine group membership.
Performance: For large numbers of users or groups, optimizing the group membership check might be necessary.
Security: Ensure proper validation and sanitization of group names to prevent security vulnerabilities.
Flexibility: Consider allowing additional attributes for the BBCode to control other behaviors (e.g., showing a message instead of hiding content).
By following these steps, you’ll have a flexible BBCode wrapper and theme component that can hide content based on group membership.
Using Gemini. I was able to get these above code snippets. However having trouble to get them to work.
If someone can guide me where to place in a custom component with the sections to input and code fix it necessary.
First error that popped up when I put the JavaScript into common was an error on “import” la ne expecting a {
Error Pic
That’s very cool!
The caveat, which you likely know, is that the text is available several ways since it’s just hidden with css. One is this post route:
/posts/123/raw
Indeed. There was a custom component someone created using a more complex way of removing content. But it seems to be broken.
Iirc it removes the content from th cooked element?
Here is the topic where a fellow created a component but when I tried it it wasn’t working and tried a pm to DeV. But might have moved on.
Sorry. I just read they you can’t get it to work.
The thing to do is use the discourse_theme to generate a new empty theme. Then look for anther theme component that has a “extends component” section… Oh. I don’t think it’ll work. You’ll need your code to target and modify what’s already in the dom. Actually, I’m not entirely sure that’s right, as I’m still pretty bad at such.
I think you can do it with just css if you use that component that adds the group membership to the css.
But the raw markdown is available in the route that i showed in my last post. I don’t see how even a plugin can make it safe such that it will be impossible for people to see the hidden text. Something like user notes might solve your problem, or if you really need it to target posts, you could use user notes as a model to make post notes that would add a post custom field that only staff could see.
Yeah, you can’t solve this properly without changing the API, so that means it would require a plugin, not a theme component.
If you aren’t using whispers on your site for moderation, perhaps you could use those which are out of the box?
The application for this would not be security centric.
This would be more for light applications. In an earlier topic a person was looking for. Something like this for table top RPG. So for example the dungeon Master might need to access a player’s character sheet. The character sheet would be visible to the Player and game masters.
The umbrella component that the one fellow made looks good. However it seems broken when I tried it out. But of course I believe even that one could be fairly easy to compromise. If not mistaken like disabling Java. Or even a clever person who knows about site safe-mode. Can safe mode be restricted to Staff/Admin?
Any component as it is client side mods are if course not meant for security needs. Even a tampermonkey script can be used by members similar or same as theme/theme components
Extend this idea further and you could In theory obscure content based on Badges etc..
yes. disabling this will make it so only staff can use safe-mode.
