Max form template content length instelling werkt niet
I set the max length 3000, but when I created a 5 input form template, it said template is too long(maximum is 500 characters)
That’s strange, see Introducing Form Templates - #61 by merefield
Hi Robert,
I’m not familiar with the ruby code, I tried only use 4 inputs in the template, it works fine, any tips for how to fix this issue for me?
You will need the maintainers to respond.
Thanks for identifying this issue @Rick_Jing. It should now be resolved :tada:
https://github.com/discourse/discourse/commit/f2059bf15fc66ec726befdff4cce6f16d06915d1
that was a fast fix, thanks for all the efforts, you make the community better and better.
Thanks Keegan, that makes it much more useful
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
