500 Internal Server Error when trying to change the owner of a post with API calls
Hi! I was trying to change the owner of a post via the API and managed to trigger a 500 Internal Server Error. I followed Reverse engineer the Discourse API to get the right endpoint and replicated it with the right parameters but I only got HTTP 500.
Topic ID is 159 and Post ID is 196 according to /t/159.json, so I sent the following POST request to /t/159/change-owner.json:
# library is aiohttp, language is Python
session = aiohttp.ClientSession("http://dspacl.itslemonchan.com", headers={
    "Api-Key": "REDACTED",
    "Api-Username": "system",
    "User-Agent": "lemon/0.1"
data = {
    "post_ids": [
        196
    "username": "lemon"
async with session.post("/t/159/change-owner.json", data=data) as resp:
    txt = await resp.text()  # so i could check if there was a message but nothing
    resp.raise_for_status()
This throws an Internal Server Error and nothing happens. After checking the logs, I get the following:
Message (2 copies reported)
NoMethodError (undefined method `to_a' for an instance of String)
app/controllers/topics_controller.rb:914:in `change_post_owners'
app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
app/controllers/application_controller.rb:424:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
lib/middleware/anonymous_cache.rb:393:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:35:in `call_app'
lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:22:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/processing_request.rb:12:in `call'
lib/middleware/request_tracker.rb:360:in `call'
Backtrace
actionpack (7.1.4) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.1.4) lib/abstract_controller/base.rb:224:in `process_action'
actionpack (7.1.4) lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack (7.1.4) lib/abstract_controller/callbacks.rb:259:in `block in process_action'
activesupport (7.1.4) lib/active_support/callbacks.rb:121:in `block in run_callbacks'
plugins/discourse-staff-alias/lib/discourse_staff_alias/topics_controller_extension.rb:22:in `block (2 levels) in <module:TopicsControllerExtension>'
activesupport (7.1.4) lib/active_support/callbacks.rb:130:in `instance_exec'
activesupport (7.1.4) lib/active_support/callbacks.rb:130:in `block in run_callbacks'
i18n (1.14.5) lib/i18n.rb:351:in `with_locale'
activesupport (7.1.4) lib/active_support/callbacks.rb:141:in `run_callbacks'
actionpack (7.1.4) lib/abstract_controller/callbacks.rb:258:in `process_action'
actionpack (7.1.4) lib/action_controller/metal/rescue.rb:25:in `process_action'
actionpack (7.1.4) lib/action_controller/metal/instrumentation.rb:74:in `block in process_action'
activesupport (7.1.4) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.1.4) lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport (7.1.4) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.1.4) lib/action_controller/metal/instrumentation.rb:73:in `process_action'
actionpack (7.1.4) lib/action_controller/metal/params_wrapper.rb:261:in `process_action'
activerecord (7.1.4) lib/active_record/railties/controller_runtime.rb:32:in `process_action'
actionpack (7.1.4) lib/abstract_controller/base.rb:160:in `process'
actionview (7.1.4) lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionpack (7.1.4) lib/action_controller/metal.rb:227:in `dispatch'
actionpack (7.1.4) lib/action_controller/metal.rb:309:in `dispatch'
actionpack (7.1.4) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.1.4) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:51:in `block in serve'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:131:in `block in find_routes'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:124:in `each'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:124:in `find_routes'
actionpack (7.1.4) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.1.4) lib/action_dispatch/routing/route_set.rb:882:in `call'
rack (2.2.9) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.9) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.9) lib/rack/head.rb:12:in `call'
actionpack (7.1.4) lib/action_dispatch/http/permissions_policy.rb:36:in `call'
rack (2.2.9) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.9) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/cookies.rb:689:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
activesupport (7.1.4) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (7.1.4) lib/action_dispatch/middleware/callbacks.rb:28:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
logster (2.20.0) lib/logster/middleware/reporter.rb:40:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/request_id.rb:28:in `call'
rack (2.2.9) lib/rack/method_override.rb:24:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.9) lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:191:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
actionpack (7.1.4) lib/action_dispatch/middleware/remote_ip.rb:92:in `call'
railties (7.1.4) lib/rails/engine.rb:536:in `call'
railties (7.1.4) lib/rails/railtie.rb:226:in `public_send'
railties (7.1.4) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.9) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.9) lib/rack/urlmap.rb:58:in `each'
rack (2.2.9) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
Env
HTTP HOSTS: dspacl.itslemonchan.com
Current Discourse version is 3.4.0.beta2-dev (deb751dfe3).
Thanks :slight_smile:
Hi, try:
data = {
    "post_ids[]": 196,
    "username": "lemon"
Interesting, this works from Python but not in postman, but the original data works in postman but not in Python.
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
