Некоторые значки не отображаются после обновления
With 3.4.0.beta2-dev installed, I have several random icons missing. They include the search icon in the top toolbar, icons on the left menu, and icons on the reply/edit/heart for a post screen.
I don’t have any Font Awesome plugins installed. What do I need to do to fix this?
1 лайк
I’m having these issues too but don’t have any Font Awesome plugins installed.
3.4.0.beta2-dev
Are you able to share a link to your site?
1 лайк
@david
2 лайка
Hi @Aaron_B :wave: yea I can see that some icons are missing even in safe mode. looks like on your site the search icon still called search instead of magnifying-glass. Can you upgrade your discourse instance and try again?
Font awesome 6.6.0 is called magnifying-glass
Font awesome 5.15 icon is called search
2 лайка
It says I have the latest version.
2 лайка
Any other suggestions to try?
Not at the moment, I’m a bit puzzled myself. :thinking: I got my test forum on the exact version you do but I can’t reproduce the issue yet.
1 лайк
Ok, here are the only plugins I have installed if that helps at all. Of note, I have two different forums on different servers (at the same version) and they have the exact same icon problem.
1 лайк
I ran the ./discourse-setup and everything is fixed!
9 лайков
