tomg
September 24, 2024, 12:45am
1
Using SemRush we are seeing these issues:
27 pages blocked from crawling, i.e.: Profile - Lendemor - Reflex
issues in the carousel on page About - Reflex the position: A value
for the position field is required for a nested ListItem and item
or url
: The item and url fields are mutually exclusive for a nested ListItem. Please remove one of them.
Firepup650
(Firepup Sixfifty)
September 24, 2024, 12:53am
AFAIK, profile pages are intentionally blocked from being indexed:
User profiles are disallowed as the version which is seen by the crawler contains no useful information.
It’s not a question of whether the server can handle it or “take the hit”, it’s the tens of thousands of effectively empty pages which will waste the crawl time allocated to your site by the search engines.
The tricky thing though is that we don’t even allow indexing on user pages.
[image]
Generally we see them as low value pages to add to Google.
Stack Overflow and a few other places do allow indexing here.
I guess a lot is depending on our strategy around user pages, they are very possibly a spam and abuse vector with mixed in privacy concerns.
Potentially if we only allowed indexing to particular groups and we had an HTML view that was better than just a blank page with a user name. Then t…
tomg
September 24, 2024, 1:17am
3
Okay this makes a lot of sense about not crawling the profile pages.
For issues in the carousel on page About - Reflex the position: A value
or url
What do you think?
Firepup650
(Firepup Sixfifty)
September 24, 2024, 1:41am
4
I don’t know about that one, I’m going to leave someone who knows more to respond about that one.
simon
September 24, 2024, 3:31am
6
I think there’s something wrong with the way SemRush is analyzing the page. Unless something has changed, Discourse doesn’t use the Carousel schema type. There’s a post from 2022 about the issue: SemRush Structured Data - #4 by Falco
Testing https://forum.reflex.dev/about on schema.org , it’s finding ItemList, AboutPage, and SiteNavigationElement schema types. No errors or warnings are being reported. You can check the results here: https://validator.schema.org/#url=https%3A%2F%2Fforum.reflex.dev%2Fabout .
tomg
September 24, 2024, 4:48pm
7
RGJ
(Richard - Communiteq)
September 24, 2024, 5:41pm
8
I do see some issues with the code
1. misplaced url
property
<div itemprop='itemListElement' itemscope itemtype='http://schema.org/ListItem'>
<meta itemprop='url' content='/u/elvis'>
<a href='/u/elvis' itemprop='item'>
<span itemprop='image'>
<img width="45" height="45" class="avatar" src="https://sea1.discourse-cdn.com/flex001/user_avatar/forum.reflex.dev/elvis/45/31_2.png">
</span>
<span itemprop='name'>
elvis
- elvis
</span>
</a>
</div>
The itemListElement
is a ListItem
The ListItem
has a property item
which is a Thing
A ListItem
can not have a url
property
A Thing
can. See ListItem - Schema.org Type
Hence, the <meta itemprop='url' content='/u/elvis'>
line should be moved two lines lower within the item
property value.
</span>
elvis
- elvis
</span>
</a>
</div>
2. missing position
This one is a bit more subjective. Google says here Dati strutturati Carosello (ItemList) | Google Search Central | Documentazione | Google for Developers that the property is required
So Google says “it’s required”.
That means “Google requires it”, not “it’s required by the schema”.
I don’t know what it’s doing but it’s not correctly validating. It should have caught #1 .
