Проблема с установкой docs
I installed the DOCS plugin on my site but when I do the ./launcher rebuild app, the docs doesn’t appear in the plugins session. Do you know what the cause is?
did you follow this guide? what steps did you do? are there any errors? more details would help.
3 лайка
Hi, I want to thank you for all the help you have given me since I joined this forum. Everything you have done for me has been very helpful and I sincerely thank you. In answer to your question, yes, I have done everything it says there. I don’t know what I’m doing wrong. Once I do the ./launcher rebuild app. I enter my panel and reboot my VPs. Or I don’t know if I should do the reboot!
2 лайка
Ok so you can start your Discourse instance, but the plugin isn’t showing up in the admin plugins page? So you’re not getting errors on start up or anything like that? I assume you edited the app.yml file. Do you have other plugins installed? :thinking:
2 лайка
