Hoe werkt het regenereren van samenvattingen?
In a Support discussion titled “How Does Regenerating Summaries Work?” tagged with ai and ai-summarize, markschmucker seeks clarity on summary regeneration rules, noting inconsistencies—especially for topics over 100 posts. After testing, they observe staff-only regeneration for smaller topics and propose a webhook-based automation to handle new posts, estimating $500/year in costs. Falco announces a backfill feature, adjustable via ai summary backfill maximum topics per hour, which markschmucker configures successfully. They later discover summaries are stored in ai_api_audit_logs and confirm backfill targets recent topics (~100 or updated recently). However, new posts don’t trigger automatic updates unless manually regenerated (for <100-post topics). Falco clarifies updates occur within 5 minutes for topics under 50 replies, noting markschmucker’s community has mostly mega-topics. A rate limit at Anthropic halts backfill; Falco confirms backfill will eventually cover all 60,000 topics if limits allow. markschmucker requests ai summary backfill maximum age to avoid costly summaries of inactive topics; Falco confirms ai summary backfill topic max age days exists (default 30 days), but markschmucker finds it uses created_at instead of updated_at, missing active old topics. They suggest changing the logic. MarcP asks if edited single-post topics (e.g., docs) can trigger updates. markschmucker proposes reducing the backfill interval to 1 minute to better utilize per-minute AI rate limits.
Can someone please explain the rules for regenerating summaries? There was some discussion that staff can regenerate summaries after one hour, but that’s not what I’m seeing. (Not sure what I’m seeing- it seems inconsistent.) If there is a new post, should it offer the option to regenerate? And to anyone, or just staff?
After experimenting, here’s what I see:
  • For topics with < 100 posts, the regenerate button is enabled immediately for staff only
  • For topics with > 100 posts, the regenerate button is not enabled, even after waiting an hour
Even if the regenerate button did enable, it’s not a viable workflow for our staff to continually hit the buttons, so I tentatively plan to implement a webhook listening for new posts that regenerates the summary using https://forum.example.com/discourse-ai/summarization/t/12345. Quick calculation says that would run around $500/year for our forum. I realize Discourse is trying to protect against an unexpected large cost.
Hey @markschmucker,
We are currently working on a backfill strategy for Topic summaries in DiscourseAI. We plan to ship it next week, and I will update you here when it lands.
We have the feature now @markschmucker, you can adjust it via the ai summary backfill maximum topics per hour site setting.
I’ve set that to 12 and on my Anthropic dashboard I see an event every 5 minutes, as expected. But I can’t see the payload from that dashboard. How can I see what summary Discourse is regenerating?
It is all stored in the ai_api_audit_logs table. If you have Data Explorer, you can use the following query:
SELECT
FROM
  ai_api_audit_logs
ORDER BY
  id DESC
LIMIT
  100
After playing with that, it looks like backfilling generates summaries for some of the Latest topics (looks like around 100 topics or topics that were updated in the past few weeks?).
During or after the backfill cycle, if a topic with a summary gets a new post, its summary is not automatically updated. (If it has < 100 posts, there is a “Regenerate” button that staff can hit manually.)
When should the topic with a new post get updated?
It should be updated in up to 5 minutes after a reply is posted, at least for normal topics with under 50 replies.
Is your community more geared towards mega-topics?
cc @Roman
Now I see there was a failure in the SummariesBackfill job- I hit a daily rate limit at Anthropic. That might be why it appeared to stop after maybe the 100 Latest topics, and also why the updated topic did not get a new summary.
So if I did not hit a rate limit, will SummariesBackfill summarize all 60,000 of our topics? Even those that have been inactive for years?
Most topics have more than 100 replies. We have 8 topics with over 1000 replies.
Yes, it starts every 5 minutes to do a batch, prioritizing the most recent active and skipping ones who already have an up to date summary.
If you configure your max limit per hour to be higher than how many topics with new activity you have per hour, on average, it will eventually backfill all your topics.
Feature request: something like ai summary backfill maximum age, so we don’t incur a lot of cost summarizing old topics with no activity say in the last six months. I estimate it would cost us $3,000 to summarize all 60,000, most of which we don’t care about.
cc @Roman
Just confirming here are you using haiku 3.5, it should produce good summaries
I’m using sonnet 3.5, for no good reason. Haiku 3.5 should cut the cost a lot. I think the feature request is still worth considering though.
yeah certainly.
I feel like we can possibly create a fancy backfilling algorithm in automation, cause there are a lot of knobs you may want to twiddle with beyond age.
  • Only these categories
  • Stuff with more than X views
  • Stuff with more than N likes
  • Stuff with accepted answers
  • Stuff newer than X
Adding 10 site settings for this will overwhelm users.
I agree with Mark. If we are to implement this for our forum, we dont want old posts getting resummarized that dont have new activity. AI is too costly at the moment considering summaries are just one small part of all the AI tools.
There is ai summary backfill topic max age days now, and it defaults to 30 days.
Old topics aren’t “resummarized” unless there is new activity.
I cleared all the summaries with rails c AiSummaries.destroy_all, and started a new run with a different LLM, using ai summary backfill topic max age days = 60. At first I had ai summary backfill maximum topics per hour set too high, so many of the newest topics failed because of rate limits. That’s my bad, but I expected after it backfilled to 60 days, it would start a new loop and backfill the failed topics. However it’s not doing that- it backfilled to 60 days and then stopped.
The job is running successfully every 5 minutes, but takes only milliseconds, so obviously isn’t finding anything to backfill.
I’m monitoring progress (or lack thereof) with Data Explorer, using the ai_summaries and ai_api_audit_logs tables.
If I manually click the Summarize button on a topic that did not get backfilled, it does generate a new summary, so I am properly connected to the AI provider, and the topics are “summarizable”.
No errors in /logs.
Ideas?
Found the problem. It’s comparing ai summary backfill topic max age days to topic.created_at, not updated_at. I think this should be changed to updated_at- I have many very active topics created two years ago which still get new posts every week, but if I use a max age of 90 days or even a year, those topics will not get summarized.
Please consider changing this.
.where("topics.created_at > current_timestamp - INTERVAL '#{max_age_days.to_i} DAY'")
I have many single post topics that are edited a lot (docs), can we update these summaries if a topic get’s updated?
Suggest changing the interval for the backfill job from 5 minutes to 1 minute if possible. Most(?) AI providers have rate limits per minute, so if the job ran every minute, you could get 5x more summaries done without exceeding the per-minute rate limits.
