Review queue malfunctioning on the Horizon theme
A bug was reported by nathank where the Review Queue malfunctions on the Horizon theme — dropdowns fail to open and the page hangs after clicking “No” — but works fine in the default theme. Console errors pointed to theme-related issues, including deprecation warnings and a null reference error in container.gjs. tgxworld attempted to reproduce but couldn’t, asking if the issue occurred on the /review route and whether theme components were involved. tobiaseigen suggested checking theme components and asked if the issue was site-specific. RGJ identified the culprit as the legal compliance plugin, fixed it, and asked nathank to verify. nathank confirmed the fix and thanked the team and RGJ. The issue is now resolved.
When using the Review Queue for a flagged topic on the Horizon theme, the page malfunctions and I get some very strange errors in the console.
First, the dropdown selections at the bottom of the flagged post are not working. They display, but the Yes and Ignore buttons do not reveal a dropdown. The No button still works, but the page hangs afterwards.
Switching to the default theme makes these problems go away, so it seems to be a theme issue. This is hosted on communiteq.com on latest.
Here is the console log:
app.js:271 ℹ️ Discourse v3.6.0.beta1 — https://github.com/discourse/discourse/commits/d63a24313a — Ember v6.6.0
deprecate.js:72 DEPRECATION: Importing `inject` from `@ember/service` is deprecated. Please import `service` instead. \[deprecation id: importing-inject-from-ember-service\] This will be removed in ember-source 7.0.0. See https://deprecations.emberjs.com/id/importing-inject-from-ember-service for more details.
(anonymous) @ deprecate.js:72
deprecated.js:62 \[THEME 4 ‘Inline PDF Previews’\] Deprecation notice: Accessing `site.mobileView` or `site.desktopView` during the site initialization can lead to errors and inconsistencies when the browser window is resized. Please move these checks to a component, transformer, or API callback that executes during page rendering. \[deprecated since Discourse 3.5.0.beta9-dev\] \[deprecation id: discourse.static-viewport-initialization\] \[info: https://meta.discourse.org/t/367810\]
a @ deprecated.js:62
deprecate.js:72 DEPRECATION: \[PLUGIN z-communiteq-features\] Importing `inject` from `@ember/service` is deprecated. Please import `service` instead. \[deprecation id: importing-inject-from-ember-service\] This will be removed in ember-source 7.0.0. See https://deprecations.emberjs.com/id/importing-inject-from-ember-service for more details.
site.js:216 ✅  Using the new ‘glimmer’ post stream!
deprecate.js:72 DEPRECATION: \[PLUGIN discourse-legal-compliance\] Importing `inject` from `@ember/service` is deprecated. Please import `service` instead. \[deprecation id: importing-inject-from-ember-service\] This will be removed in ember-source 7.0.0. See https://deprecations.emberjs.com/id/importing-inject-from-ember-service for more details.
index.js:51 Uncaught (in promise) TypeError: Invalid value used as weak map key
at WeakMap.set ()
at p.helper (index.js:51:71)
at m (index.js:89:20)
at index.js:253:60
at w (index.js:266:7)
at o (index.js:1210:5)
at index.js:636:33
at S.compile (index.js:448:14)
at x (index.js:461:43)
at index.js:935:11
at V (index.js:979:3)
at index.js:1084:5
at index.js:178:11
at w (index.js:192:7)
at index.js:1083:30
at index.js:1212:49
at index.js:1214:1
at ei.compile (index.js:1193:5)
at tH.compile (index.js:3771:31)
at Object.evaluate (index.js:506:25)
at Object.evaluate (index.js:103:106)
at tr.evaluateSyscall (index.js:2873:20)
at tr.evaluateInner (index.js:2852:64)
at tr.evaluateOuter (index.js:2849:10)
at tH.next (index.js:4167:45)
at tH.\_execute (index.js:4157:21)
at tH.execute (index.js:4133:41)
at tj.handleException (index.js:3450:19)
at tR.handleException (index.js:3592:52)
at tF.throw (index.js:3414:16)
at G.evaluate (index.js:565:42)
at tF.\_execute (index.js:3401:34)
at tF.execute (index.js:3393:17)
at tU.rerender (index.js:3610:8)
at tq.render (index-BCp6wOJU.js:4639:55)
at index-BCp6wOJU.js:4934:16
at eX (index.js:2414:7)
at tG.\_renderRoots (index-BCp6wOJU.js:4914:7)
at tG.\_renderRootsTransaction (index-BCp6wOJU.js:4962:12)
at tG.\_revalidate (index-BCp6wOJU.js:4995:10)
at invoke (index.js:262:14)
at m.flush (index.js:180:11)
at g.flush (index.js:334:19)
at q.\_end (index.js:762:32)
at index.js:499:12
container.gjs:270 Uncaught TypeError: Cannot read properties of null (reading ‘postStream’)
at R.calculatePosition (container.gjs:270:30)
at q.\_join (index.js:788:21)
at q.join (index.js:605:17)
at p (index.js:152:22)
at R. (index.js:250:23)
at R.postScrolled (container.gjs:413:10)
at r. (index.js:250:23)
at q (cache-fCezwMOy.js:471:12)
at r.trigger (evented.js:68:5)
at J.currentPostScrolled (topic.js:541:20)
at #rT (post-stream-viewport-tracker.js:723:30)
at #rS (post-stream-viewport-tracker.js:759:35)
at invoke (index.js:264:14)
at q.end (index.js:565:10)
at q.\_runExpiredTimers (index.js:869:12)
calculatePosition @ container.gjs:270
\_join @ index.js:788
join @ index.js:605
p @ index.js:152
(anonymous) @ index.js:250
postScrolled @ container.gjs:413
join @ index.js:605
p @ index.js:152
q @ cache-fCezwMOy.js:471
trigger @ evented.js:68
currentPostScrolled @ topic.js:541
#rT @ post-stream-viewport-tracker.js:723
#rS @ post-stream-viewport-tracker.js:759
invoke @ index.js:264
flush @ index.js:180
flush @ index.js:334
\_end @ index.js:762
end @ index.js:565
\_runExpiredTimers @ index.js:869
setTimeout
setTimeout @ index.js:39
\_installTimerTimeout @ index.js:912
\_later @ index.js:823
debounce @ index.js:680
C @ index.js:713
r @ debounce.js:26
#rp @ post-stream-viewport-tracker.js:897
end @ index.js:565
setTimeout
\_reinstallTimerTimeout @ index.js:896
debounce @ index.js:701
C @ index.js:713
r @ debounce.js:26
onScroll @ post-stream-viewport-tracker.js:573
\_run @ index.js:804
\_join @ index.js:783
join @ index.js:605
p @ index.js:152
join @ index.js:605
p @ index.js:152
join @ index.js:605
p @ index.js:152
end @ index.js:565
setTimeout
C @ index.js:713
r @ debounce.js:26
end @ index.js:565
setTimeout
C @ index.js:713
r @ debounce.js:26
join @ index.js:605
p @ index.js:152
join @ index.js:605
p @ index.js:152
join @ index.js:605
p @ index.js:152
end @ index.js:565
setTimeout
C @ index.js:713
r @ debounce.js:26
end @ index.js:565
setTimeout
C @ index.js:713
r @ debounce.js:26
join @ index.js:605
p @ index.js:152
join @ index.js:605
p @ index.js:152
join @ index.js:605
p @ index.js:152
end @ index.js:565
setTimeout
C @ index.js:713
r @ debounce.js:26
end @ index.js:565
setTimeout
C @ index.js:713
r @ debounce.js:26
join @ index.js:605
p @ index.js:152
Thank you for the report but I’m currently unable to reproduce this locally or on this site.
Is this the /review route?
Are there theme components installed on your horizon theme?
@RGJ pinging you in case you are not aware.
@nathank are you getting this on more than one site, or is it just one site? If so like tgx says I would look at the theme components you have enabled for that particular theme on the site.
It’s the legal compliance plugin acting up. We’re investigating.
EDIT found and fixed, @nathank could you try if the issue is gone?
Yup, working beautifully now.
Thanks both the Discourse team (sorry for pestering you unnecessarily) and @RGJ!
This topic was automatically closed after 2 days. New replies are no longer allowed.
