Load average ×2 since last upgrade
I upgraded to 2025.12.0-latest from a release that was not calver yet (how to know exactly? I don’t remember the version).
So yes I skipped over 2025.11 (was not proposed by the Discourse upgrade page), maybe a bug due to the change in release numbering? I don’t know. Anyway I upgraded.
It went well but right after the upgrade the forum was particularly slow.
A few hours later it felt less slow but I noticed a difference in the load average:
It bumped from less than 0.1 to more than 0.2. The rise is exactly from the moment I did the upgrade.
Am I alone noticing this?
לייק 1
Hum I’m seeing an error in the logs that was not present before the upgrade:
DistributedMutex("activity_pub_process_[...]"): held for too long, expected max: 120 secs, took an extra 27 secs
Maybe it is related.
לייק 1
Today I tried disabling ActivityPub to see if loads get back at the pre-upgrade level, and it does.
So enabling activity pub more than doubles my load average since around 2025-11 / 2025-12, there’s probably some kind of issue there.
Here’s the load graph, I disabled the plugin at 16h48, see the drop:
3 לייקים
Load went back to normal on 2025-12-20 around 10 PM UTC+1, and I do no longer see the DistributedMutex held for too long error…
3 לייקים
Load went back to normal with ActivityPub enabled again?
Any chance you can share a backtrace for this error? I am not seeing it on two instances that we have running with the plugin enabled.
Yes, here it is:
Message
DistributedMutex("activity_pub_process_4cce076d079ee338eb556919769918f9"): held for too long, expected max: 120 secs, took an extra 39 secs
Backtrace
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/broadcast_logger.rb:218:in `block in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/broadcast_logger.rb:217:in `map'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/broadcast_logger.rb:217:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/broadcast_logger.rb:129:in `warn'
/var/www/discourse/lib/distributed_mutex.rb:103:in `warn'
/var/www/discourse/lib/distributed_mutex.rb:57:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/plugins/discourse-activity-pub/app/jobs/regular/discourse_activity_pub/process.rb:9:in `execute'
/var/www/discourse/app/jobs/base.rb:318:in `block (2 levels) in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-7.0.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-7.0.0/lib/rails_multisite/connection_management.rb:17:in `with_connection'
/var/www/discourse/app/jobs/base.rb:305:in `block in perform'
/var/www/discourse/app/jobs/base.rb:301:in `each'
/var/www/discourse/app/jobs/base.rb:301:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:220:in `execute_job'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:185:in `block (4 levels) in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:180:in `traverse'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:183:in `block in traverse'
/var/www/discourse/lib/sidekiq/suppress_user_email_errors.rb:6:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:182:in `traverse'
/var/www/discourse/lib/sidekiq/discourse_event.rb:6:in `call'
/var/www/discourse/lib/sidekiq/pausable.rb:131:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job/interrupt_handler.rb:9:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:26:in `track'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:134:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:173:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:184:in `block (3 levels) in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:145:in `block (6 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_retry.rb:118:in `local'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:144:in `block (5 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/config.rb:39:in `block in <class:Config>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:139:in `block (4 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:281:in `stats'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:134:in `block (3 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_logger.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:133:in `block (2 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_retry.rb:85:in `global'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:132:in `block in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_logger.rb:40:in `prepare'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:131:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:183:in `block (2 levels) in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in `block in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in `process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:86:in `process_one'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:76:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/component.rb:10:in `watchdog'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/component.rb:19:in `block in safe_thread'
לייק 1
