502 Error / Unicorn Timeout on Rewind page for highly active users
Hello :waving_hand:
We are experiencing an issue with the Discourse Rewind plugin. For some of our most active users, the Rewind page fails to load and returns a 502 error.
  • The issue seems to be a timeout during the data aggregation process.
  • It consistently happens for users with high activity levels, while working fine for average users.
  • The logs indicate that the Unicorn worker receives a USR2 signal because it exceeds the timeout limit while executing a database query.
Error in console:
Warning in logs:
Message
Unicorn worker received USR2 signal indicating it is about to timeout, dumping backtrace for main thread
config/unicorn.conf.rb:204:in `backtrace'
config/unicorn.conf.rb:204:in `block (2 levels) in reload'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-4.0.1/lib/patches/db/pg/alias_method.rb:112:in `exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-4.0.1/lib/patches/db/pg/alias_method.rb:112:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/postgresql/database_statements.rb:167:in `perform_query'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:556:in `block (2 levels) in raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract_adapter.rb:1017:in `block in with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract_adapter.rb:986:in `with_raw_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:555:in `block in raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract_adapter.rb:1137:in `log'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:554:in `raw_execute'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-8.0.4/lib/active_record/connection_adapters/abstract/database_statements.rb:591:in `...
Backtrace
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/broadcast_logger.rb:218:in `block in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/broadcast_logger.rb:217:in `map'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/broadcast_logger.rb:217:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-8.0.4/lib/active_support/broadcast_logger.rb:129:in `warn'
/var/www/discourse/lib/signal_trap_logger.rb:40:in `public_send'
/var/www/discourse/lib/signal_trap_logger.rb:40:in `block (2 levels) in ensure_logging_thread_running'
<internal:kernel>:187:in `loop'
/var/www/discourse/lib/signal_trap_logger.rb:37:in `block in ensure_logging_thread_running'
Thanks
Thanks @Don what scale are we talking here, can you give us a clue on how active this user is? (posts a year / likes a year)
Sure, here are some stats (last year) for two of the affected users:
User 1
  • Posts created: 11,709
  • Reactions given: 41,569
  • Reactions received: 74,603
User 2
  • Posts created: 5,959
  • Reactions given: 37,974
  • Reactions received: 38,875
Both users trigger the 502 error, suggesting the timeout threshold is hit even with the moderately lower (but still high) activity of User 2.
Thanks heaps Don, someone will have a look over the next couple of weeks.
I think this fix should help:
