Hi! We think profile pics are very important for our forum to have the community feel we’re shooting for.
What are best practices for encouraging profile pics?
One complication is that we need users to go through an approval process before entering Discourse, and I don’t know if that works alongside social log-ins (which we totally want to encourage.)
I’ve been thinking about this too, especially for highly active/visible members. Getting them to have a nice avatar image would turn it into ‘leading by example’. I got stuck in finding an automated solution that would DM such users when they posted something. Instead, I think I’ll go with Dave’s solution for a while and see if a small effort can make me reach a tipping point here.
There’s already a reminder that pops up dynamically after you’ve replied a few times and are no longer TL0, and still carry a default avatar.
@tshenry can you test to verify that this is still working on try (remember to reset default TL to 0 before creating an account, as try is TL1 by default)?
I kicked off a new account on try at TL0. When I was naturally promoted to TL1, I received the following message which suggests to fill out the user’s profile:
I opened a PR for one area I thought could use improvement. Currently the “visiting your user profile” link in the education message points to the base user profile page. The profile picture setting is at least another click and some scrolling down for a new user, it seems like it might be better to take the user right to it.
Providing a direct link to the page where users can add a profile picture in the first message they received has helped. It’s a step that most people are familiar with given other social media platforms, so they were able to figure it out pretty easily.
줄리, 안녕하세요.
이 주제가 시작된 이후로 크게 변한 것은 없습니다. 사용자가 커스텀 아바타를 업로드하도록 유도하는 방법은 여러 가지가 있고, 기본 아바타를 설정하는 옵션도 몇 가지 있지만, 커스텀 아바타 사용을 의무화하는 표준 제공 솔루션은 없습니다. 이를 구현하려면 작은 플러그인이 필요하며, 이는 저희 스탠다드 플랜에서는 제공되지 않습니다.
곧 저희 Discourse 사이트를 출시할 예정입니다. 사용자들이 그동안 listserv 플랫폼에 익숙해져 있어서, 이메일로 답글을 보내고 이메일로 새 게시물을 시작할 수 있도록 이메일 설정을 구성해 두었습니다.
하지만 프로필 사진과 관련하여 이해가 안 되는 부분이 있습니다. 어떤 때는 발신자의 프로필 사진과 함께 잘 포맷된 “토픽 방문” 링크(버튼처럼 보이는 형태)가 포함된 이메일을 받지만, 다른 때는 새 메시지가 덜 예쁜 형태로 도착합니다. 프로필 사진이 없고 "토픽 방문"은 단순한 하이퍼링크로 표시됩니다.
저는 그들에게 우리가 인간이며, 대화 상대가 누구인지 보고 (또는 직감으로) 느끼고 싶다고 말합니다. 그리고 얼굴 사진을 올리고 싶지 않다면, 제 커뮤니티에서 실제 사용자들의 사진을 예로 들 수 있습니다. 일부만 보이는 사진, 이펙트를 적용한 사진, 만화 캐릭터 등 무엇이든 괜찮지만, 사람이어야 합니다.
