Pulsanti del piè di pagina dell'argomento
:discourse2: Summary Custom Topic Button defines a button visible at the bottom of your topic to open a URL of your choice.
Custom Group Topic Button defines a button visible at the bottom of your topic to open a URL of your choice, with added group visibility options.
:eyeglasses: Preview Preview on Discourse Theme Creator
(Custom Topic Button)
:hammer_and_wrench: Repository Link(s) https://github.com/discourse/discourse-custom-topic-button-component
https://github.com/discourse/discourse-topic-group-button-component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install Custom Topic Button
Install Custom Group Topic Button
Features
Hi, let me introduce you to two new simple theme components which have essentially the same goal but are slightly different:
This component will let you define a button visible at the bottom of your topic to open a URL of your choice.
You can customise label/title/icon/link. Links accept multiple placeholders:
<TOPIC_ID>
<USER_ID>
<USERNAME>
<TOPIC_TITLE>
<TOPIC_SLUG>
which will be replaced accordingly.
Has the same behaviour, except you can define a group to limit the visibility of this button.
These components are very simple right now, we could improve them in the future if we see real usage of them and issues.
Settings
Custom Topic Button
Name Description
custom topic button enabled
custom topic button url
custom topic button title Button description here..
custom topic button label Click Me
custom topic button icon
Name Description
topic group button enabled
topic group button url
topic group button title Button description here..
topic group button label Click Me
topic group button allowed group
topic group button icon
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
22 Mi Piace
Non credo funzioni. Ho provato io stesso api.registerTopicFooterButton e non funziona, nemmeno il link di anteprima.
Sospetto sia a causa del tag script. Il modo normale di usare javascripts/discourse funziona.
Funziona per me, ho provato il primo componente così com’è:
Strano. Sul mio telefono e sul mio laptop, il link di anteprima di Theme Creator porta a un argomento senza tale pulsante.
1 Mi Piace
Oh, intendevi sul Theme Creator; non funziona nemmeno per me. Su un’installazione locale, tuttavia, funziona.
3 Mi Piace
