Install Discourse on Ubuntu or Debian for Development
:warning: This guide covers installation instructions in a development environment. For a production guide see: Install Discourse in production with the official supported instructions
So you want to set up Discourse on Ubuntu or Debian to hack on and develop with?
We’ll assume that you work locally and don’t have Ruby/Rails/Postgres/Redis installed on your Ubuntu or Debian system. Let’s begin!
Requirements
We suggest having at least 4 GB RAM and 2 CPU cores.
Current compatibility:
OS Compatibility
Debian 11 :white_check_mark:
Crostini (Linux on ChromeOS) :white_check_mark:
Ubuntu 22.04 or later :white_check_mark:
Install Discourse Dependencies
You will need the following packages on your system:
** optional
Now that we have installed Discourse dependencies, let’s move on to install Discourse itself.
Clone Discourse
Clone the Discourse repository in ~/discourse folder:
git clone https://github.com/discourse/discourse.git ~/discourse
~ indicates home folder, so Discourse source code will be available in your home folder.
Setup Database
Create role with the same name as your Linux system username:
cd /tmp && sudo -u postgres createuser -s "$USER"
[/details]
Bootstrap Discourse
Switch to your Discourse folder:
 cd ~/discourse
Install the needed gems
source ~/.bashrc
bundle install
Install the JS dependencies
pnpm install
Now that you have successfully installed gems, run these commands:
bin/rails db:create
bin/rails db:migrate
RAILS_ENV=test bin/rails db:create db:migrate
Start rails and the frontend bundler:
bin/dev
If the images are not appearing, use this command instead:
(you can also specify an IP if you are working on a remote server)
DISCOURSE_HOSTNAME=localhost UNICORN_LISTENER=localhost:3000 bin/dev
You should now be able to navigate to http://localhost:3000 to see your local Discourse installation.
Create New Admin
To create a new admin, run the following command:
bin/rails admin:create
Follow the prompts, and a new admin account will be created.
Configure Mail
Run MailHog:
mailhog
Congratulations! You are now the admin of your own Discourse installation!
Happy hacking! And to get started with that, see Beginner’s Guide to Creating Discourse Plugins.
Last Reviewed by @blake on 2023-04-03T06:00:00Z
This document is version controlled - suggest changes on github.
Docker setup for development
Share your Discourse dev setup
How to open via internal IP?
Discourse as Your First Rails App
Why is my dev server not showing me uploaded images in Topics?
Unable to Install Discourse for development
Can I install discourse on my local machine
Bitnami Discourse VM on Virtualbox + SMTP mail-server for testing
Not receiving Activation Email
Jhead and svgo errors while running specs
Mini_racer installation issues on ubuntu vagrant (OSX)
Issue in setup discourse on ubuntu server
Override profile background via SSO
Can't set up dev environment due to cppjieba_rb failing to install
Can't install the bundle
How to add a new language
Rspec failing to load when using the official beginners guide
How do I go about making a very customized theme?
Export only database data Postgres (for users, posts and topics)
Moderation Tools
Any interest in Podman?
Bundler cannot continue due installation error of mini_racer 0.4.0
How to setup discourse in my local for development?
How might we better structure #howto?
Please help, how do I install Discourse on macOS?
Can't reach Discourse server in VM from Host
Images are not being populated in discourse
How to install Discourse locally?
Discourse Local setup
Is this correct? How long to install dev Version?
Overriding user_guardian.rb in a plugin (no fork necessary!)
How Sam's Windows development environment is configured
Site setting is different Every time on Ubuntu development installation
Problems with understanding the development of Discourse
How do I change the address in the database?
Discourse on local pc
Error while importing topics from Flarum (users, groups import OK)
Flarum To Discourse Migration
Problem in development Installation
Calling out for Testers
Developing on the mobile version of Discourse
Can't build Discourse on Ubuntu 20.10
Discourse standalone
Set up a local Discourse Development Environment?
Unable to setup discourse
Migrate a phpBB3 forum to Discourse
Migrate a vBulletin 4 forum to Discourse
Migrate a FluxBB forum to Discourse
Migrate a NodeBB forum with Redis to Discourse
Migrate a MyBB forum to Discourse
Migrate a NodeBB forum with MongoDB to Discourse
Migrate a Ning forum to Discourse
Migrate a Phorum forum to Discourse
Migrate a PunBB forum to Discourse
Migrate from another forum to Discourse
Migrate a Kunena 3 forum to Discourse
Migrate a bbPress WordPress plugin forum to Discourse
Use the Discourse API ruby gem
Use Screen To Bootstrap A Development Install (Ubuntu)
Set up Discourse for development on Fedora Linux
Need to restart Ember in order to test front-end changes
Error installing `bullseye-backports` when trying to install for Development
Local installation internal use only
ImageMagick Install Fails during Dev Installation on Ubuntu 22.04.1
Installing Plugins in Discourse Development Install
Discourse dev install script may need upgrade
I'm having trouble installing a local Discourse instance on Windows 11
Login popup not display
Not able to restore discourse docker backup on Ubuntu discourse installation
Installing Discourse on windows using Docker Desktop
End-to-end system testing for themes and theme components
CSRF problem in development with 'Discourse OpenID Connect' plug-in
Need help integrating code wrote on Edittext to the Discourse
Integration into custom auth system where emails are not unique?
Contributing to Discourse development
Development install fails when running bin/rails db:migrate
Developing Discourse on GitHub Codespaces
Install Discourse on Windows for development
Connecting WP Discourse to a local Discourse Instance running a specific version
Chat not working after dev install
Discourse Ember CLI Proxy Error
Bundling more popular plugins with Discourse core
Dev environment: recommended way to bootstrap the first admin account without email?
Migrate from GetSatisfaction to Discourse
Developing Discourse Plugins - Part 6 - Add acceptance tests
Install Discourse for development using Docker
Install Discourse on macOS for development
Discourse Server logs show DB queries when I run the server
Docker in VMWare - How to access to Discourse
How can I make my own Discourse plugins?
What is the latest recommended workflow for local development? (Ubuntu 16.04)
How to customize the Discourse app using docker container?
Uploads location on dev instance?
Update PhantomJS to latest for Ubuntu dev guide?
A check for updates has not been performed lately. Ensure sidekiq is running
How to fix bundler executable conflicts in the `techAPJ/install-rails` script?
Ubuntu development install: Permission denied @ apply2files
Install discourse on localhost
Trouble getting a top level page to Ember
Formal german available?
Rake aborted message is showing when installing vagrant development
Where is the db connection information discourse?
How to install the bootsnap gem?
State of disqus to discourse importer
Connecting to Droplet
Install and import Mysql on the development environment
Can't uninstall on Ubuntu 18.04
How to install Discourse on windows
Discourse running very slow on local machine
Can't find the Discourse folder inside virtual box via ssh
Importing MyBB database to Discourse
How to create new user with verified email in development mode?
Unable to create Vagrant local installation
Installing problem - bundle install
How to get a docker image of discourse using bash on windows 10?
Attachment filename not set on download
[PAID] Import from Legacy Postgres DB
Does Gemfile need to include svg?
Database wont migrate Discourse
I want to build a debug version of discourse
How to reset discourse on dev mode? (w/o docker)
Nodebb to Discourse
RSpec search_spec.rb RateLimiter LimitExceeded problems
Issue with vagrant version following the dev guide
Which is the better option to self-host?
NULL first_visited_at dates in the topic_users table
Multiple instances. Visiting the second instance signs out the logged in account on the running instance
Can't run my Discourse locally
I want to install a plugin for development, what should I do?
Vbulletin 4 import -
Hello from Gitpod! (installing on google cloud + automated dev setup)
How to Install Discourse on LocalHost in Windows?
Migrating a myBB forum to Discourse using Kubuntu in a VM
Migration from Yahoo! Groups
Does the forum for development start up 24 hours*?
How to allow customs hosts in development mode
Help with setting up discourse An error occurred while installing xorcist (1.1.2), and Bundler cannot continue
fixed it by removing the calendar plugin. :thinking:
install is very slow
I’ve been trying for about 45min to get it to connect to my local DB but can’t figure it out:
discourse $bin/rails db:create
We could not find your database: postgres. Which can be found in the database configuration file located at config/database.yml
Here is the full trace:
discourse $bin/rails db:create --trace
** Invoke db:create (first_time)
** Invoke db:force_skip_persist (first_time)
** Execute db:force_skip_persist
** Invoke db:load_config (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute db:load_config
** Execute db:create
We could not find your database: postgres. Which can be found in the database configuration file located at config/database.yml.
To resolve this issue:
- Did you create the database for this app, or delete it? You may need to create your database.
- Has the database name changed? Check your database.yml config has the correct database name.
To create your database, run:
        bin/rails db:create
Couldn't create 'discourse_development' database. Please check your configuration.
rails aborted!
ActiveRecord::NoDatabaseError: We could not find your database: postgres. Which can be found in the database configuration file located at config/database.yml. (ActiveRecord::NoDatabaseError)
        bin/rails db:create
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/postgresql_adapter.rb:81:in `rescue in new_client'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/postgresql_adapter.rb:77:in `new_client'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/postgresql_adapter.rb:37:in `postgresql_connection'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:656:in `public_send'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:656:in `new_connection'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:700:in `checkout_new_connection'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:679:in `try_to_checkout_new_connection'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:640:in `acquire_connection'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:341:in `checkout'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_pool.rb:181:in `connection'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/abstract/connection_handler.rb:211:in `retrieve_connection'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_handling.rb:313:in `retrieve_connection'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_handling.rb:280:in `connection'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/tasks/postgresql_database_tasks.rb:12:in `connection'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/tasks/postgresql_database_tasks.rb:26:in `create'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/tasks/database_tasks.rb:122:in `create'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/tasks/database_tasks.rb:184:in `block in create_current'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse_dev_assets-0.0.4/lib/discourse_dev_assets.rb:27:in `block in each_current_configuration'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/tasks/database_tasks.rb:557:in `block (2 levels) in each_current_configuration'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/tasks/database_tasks.rb:554:in `each'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/tasks/database_tasks.rb:554:in `block in each_current_configuration'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/tasks/database_tasks.rb:553:in `each'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/tasks/database_tasks.rb:553:in `each_current_configuration'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/discourse_dev_assets-0.0.4/lib/discourse_dev_assets.rb:22:in `each_current_configuration'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/tasks/database_tasks.rb:184:in `create_current'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/railties/databases.rake:45:in `block (2 levels) in <main>'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `block in execute'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `each'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:281:in `execute'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:219:in `block in invoke_with_call_chain'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `synchronize'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:199:in `invoke_with_call_chain'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/task.rb:188:in `invoke'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:188:in `invoke_task'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block (2 levels) in top_level'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `each'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:138:in `block in top_level'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:147:in `run_with_threads'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:132:in `top_level'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.0.8.1/lib/rails/commands/rake/rake_command.rb:24:in `block (2 levels) in perform'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/application.rb:214:in `standard_exception_handling'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.0.8.1/lib/rails/commands/rake/rake_command.rb:24:in `block in perform'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/rake-13.2.1/lib/rake/rake_module.rb:59:in `with_application'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.0.8.1/lib/rails/commands/rake/rake_command.rb:18:in `perform'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.0.8.1/lib/rails/command.rb:51:in `invoke'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/railties-7.0.8.1/lib/rails/commands.rb:18:in `<main>'
<internal:/home/dylan/.rbenv/versions/3.2.1/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:37:in `require'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/bootsnap-1.18.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
Caused by:
PG::ConnectionBad: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: fe_sendauth: no password supplied (PG::ConnectionBad)
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/pg-1.5.4/lib/pg/connection.rb:696:in `async_connect_or_reset'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/pg-1.5.4/lib/pg/connection.rb:824:in `connect_to_hosts'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/pg-1.5.4/lib/pg/connection.rb:759:in `new'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/pg-1.5.4/lib/pg.rb:63:in `connect'
/home/dylan/.rbenv/versions/3.2.1/lib/ruby/gems/3.2.0/gems/activerecord-7.0.8.1/lib/active_record/connection_adapters/postgresql_adapter.rb:78:in `new_client'
Tasks: TOP => db:create
Hello. Try to install on ubuntu server 24, and can not install imagemagick:
console log
install-imagemagick                                         100%[========================================================================================================================================>]   2.57K  --.-KB/s    in 0s
2024-06-23 14:08:00 (13.4 MB/s) - ‘install-imagemagick’ saved [2631/2631]
Reading package lists...
Building dependency tree...
Reading state information...
Package 'imagemagick' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
E: Unable to locate package libwebp6
E: Unable to locate package libltdl7-dev
Looks like on ubuntu need to be installed libwebp7 not libwebp6, but in script exist check libwebp version for ubuntu 22 only:
# Ubuntu 22.04/22.10  doesn't have libwebp6
LIBWEBP=$(cat /etc/issue | grep -qi 'Ubuntu 22' && echo 'libwebp7' || echo 'libwebp6')
I think, this code must be edited to instal libwebp7 in any way…
I have the same problem. Any suggestions?
I download main script:
https://raw.githubusercontent.com/discourse/install-rails/main/linux
and download install-imagemagick
In script install-imagemagick I edit string 12
to
LIBWEBP=$(cat /etc/issue | grep -qi 'Ubuntu 22' && echo 'libwebp7' || echo 'libwebp7')
Also I edit at 105 string in main script, where it calling install-imagemagick script, so, in this line, my edited install-imagemagick installation file would be called, and not the original one.
Now I have new error:
The value 'bullseye-backports' is invalid for APT::Default-Release as such a release is not available in the sources
failed
I give up…
I think it should be noted here that the instructions from the first post not actual at this time.
Will try with docker
I did a PR a while back to add support for Ubuntu 20 and Debian 12. I guess I will need to revisit it.
https://github.com/discourse/discourse_docker/pull/750/files
For Ubuntu 24, you would need to change the regular expressions to something like:
grep -qiE 'Ubuntu 2[2-9]'
You can remove the check as I did in the PR.
You can use this updated version, in your case:
#!/bin/bash
set -e
# version check: https://github.com/ImageMagick/ImageMagick/releases
IMAGE_MAGICK_VERSION="7.1.0-62"
IMAGE_MAGICK_HASH="d282117bc6d0e91ad1ad685d096623b96ed8e229f911c891d83277b350ef884a"
# We use debian, but GitHub CI is stuck on Ubuntu Bionic, so this must be compatible with both
LIBJPEGTURBO=$(cat /etc/issue | grep -qi Debian && echo 'libjpeg62-turbo libjpeg62-turbo-dev' || echo 'libjpeg-turbo8 libjpeg-turbo8-dev')
# Ubuntu 22/23/24 and Debian 12 don't have libwebp6
LIBWEBP=$(cat /etc/issue | grep -qiE 'Ubuntu 22|Debian.*12' && echo 'libwebp7' || echo 'libwebp6')
PREFIX=/usr/local
WDIR=/tmp/imagemagick
# Install build deps
apt -y -q remove imagemagick
apt -y -q install git make gcc pkg-config autoconf curl g++ yasm cmake \
    libde265-0 libde265-dev ${LIBJPEGTURBO} x265 libx265-dev libtool \
    libpng16-16 libpng-dev ${LIBJPEGTURBO} ${LIBWEBP} libwebp-dev libgomp1 \
    libwebpmux3 libwebpdemux2 ghostscript libxml2-dev libxml2-utils librsvg2-dev \
    libltdl7-dev libbz2-dev gsfonts libtiff-dev libfreetype6-dev libjpeg-dev
apt -y install libheif1 libaom-dev libheif-dev
mkdir -p $WDIR
cd $WDIR
# Build and install ImageMagick
wget -q -O $WDIR/ImageMagick.tar.gz "https://github.com/ImageMagick/ImageMagick/archive/$IMAGE_MAGICK_VERSION.tar.gz"
sha256sum $WDIR/ImageMagick.tar.gz
echo "$IMAGE_MAGICK_HASH $WDIR/ImageMagick.tar.gz" | sha256sum -c
IMDIR=$WDIR/$(tar tzf $WDIR/ImageMagick.tar.gz --wildcards "ImageMagick-*/configure" |cut -d/ -f1)
tar zxf $WDIR/ImageMagick.tar.gz -C $WDIR
cd $IMDIR
PKG_CONF_LIBDIR=$PREFIX/lib LDFLAGS=-L$PREFIX/lib CFLAGS=-I$PREFIX/include ./configure \
          --prefix=$PREFIX \
          --enable-static \
          --enable-bounds-checking \
          --enable-hdri \
          --enable-hugepages \
          --with-threads \
          --with-modules \
          --with-quantum-depth=16 \
          --without-magick-plus-plus \
          --with-bzlib \
          --with-zlib \
          --without-autotrace \
          --with-freetype \
          --with-jpeg \
          --without-lcms \
          --with-lzma \
          --with-png \
          --with-tiff \
          --with-heic \
          --with-rsvg \
          --with-webp
make all && make install
cd $HOME
rm -rf $WDIR
ldconfig /usr/local/lib
# Validate ImageMagick install
test $(convert -version | grep -o -e png -e tiff -e jpeg -e freetype -e heic -e webp | wc -l) -eq 6
Yes. Its working, thank you! I have some doubt question. How I can configure discourse to use it from LAN for debug? My ubuntu is Hyper-V Ubuntu Server, so, I use not “localhost” for accessing discourse, but local ip address (192.168.2.20 in my case), from another PC browser, and all “self hosted” images is not accessebly with error - 404 (because they have url - //localhost:4200/uploads/default/original/2X/8/81ce02e47fa4b791e9cb4b880c6c4dab9e0b6d9d.png), and of cause its not worked from LAN)
2 posts were split to a new topic: Docker-less production install
TL;DR: Please merge #750. Legacy systems always comes with trouble.
Casually phrased, the instructions do state:
In case anyone else makes the mistake of believing it is just a friendly suggestion, please think again. Any attempt to launch with 1 GiB RAM and 4 GiB of swap will result, not in degraded performance, but in:
Error compiling CSS asset
RuntimeError: Discourse does not support compiling scss/sass files via Sprockets
…/discourse/config/application.rb:190:in `call’
Which according to this thread is a symptom of an insufficient RAM allocation.
Eventually one might also be lucky enough to get a JavaScript stack trace starting with:
FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
So follow the instructions! I’m off to redo this exercise with a freshly created VPS. Rather than attempting to mock around with setting up something as old and outdated, I instead tried repurposing an old decommissioned bullseye one I happened to have still running.
Maybe a second reviewer would wish to look at that PR adding bookworm support, so I’ll be the last sucker getting hit by this?
I made a second attempt, on an Ubuntu 22.04.4 LTS (Jammy Jellyfish), and now seem to have a working development environment. That took a couple of attempts though, since the instructions lack one very important command.
A crucial step before running ./linux is to create them gem cache directory:
mkdir --parent /home/discourse/.cache/gem
Missing that step will cause the directory to be created with root:root permissions, which makes the installation fail when running it with a freshly created user account.
Comeplete Setup
Gist Link : Discourse SetUp · GitHub
1.Paste this Command
bash <(wget -qO- https://raw.githubusercontent.com/discourse/install-rails/main/linux)
2.You will get this Error
Installing ImageMagick …
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
libtool is already the newest version (2.4.7-7build1).
The following packages were automatically installed and are no longer required:
  graphicsmagick libgraphicsmagick-q16-3t64 libhwy1t64 libjpeg9 libjxl0.7
Use 'sudo apt autoremove' to remove them.
--2024-08-14 03:41:23--  https://raw.githubusercontent.com/discourse/discourse_docker/main/image/base/install-imagemagick
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.108.133, 185.199.109.133, 185.199.111.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.108.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 2624 (2.6K) [text/plain]
Saving to: ‘install-imagemagick.3’
install-imagemagick.3   100%[===============================>]   2.56K  --.-KB/s    in 0s
**2024-08-14 03:41:23 (32.6 MB/s) - ‘install-imagemagick.3’ saved [2624/2624]**
**chmod: changing permissions of 'install-imagemagick': Operation not permitted**
**failed**
  1. sudo apt-get install imagemagick
  2. magick --version
    You will get This Error
    test@tworks:~$ magick --version
    Command ‘magick’ not found, did you mean:
    command ‘magics’ from deb magics++ (4.14.2-2)
    command ‘magic’ from deb magic (8.3.105+ds.1-1.1)
    Try: sudo apt install
  3. cd
  4. sudo apt install build-essential make git
  5. git clone GitHub - ImageMagick/ImageMagick: ImageMagick is a free, open-source software suite for creating, editing, converting, and displaying images. It supports 200+ formats and offers powerful command-line tools and APIs for automation, scripting, and integration across platforms. · GitHub
  6. cd ImageMagick
  7. ./configure
  8. make
  9. sudo make install
  10. sudo ldconfig /usr/local/lib
  11. convert -version
**Output**
test@tworks:~/ImageMagick$ convert -version
Version: ImageMagick 6.9.12-98 Q16 x86_64 18038 https://legacy.imagemagick.org
Copyright: (C) 1999 ImageMagick Studio LLC
License: https://imagemagick.org/script/license.php
Features: Cipher DPC Modules OpenMP(4.5)
Delegates (built-in): bzlib djvu fftw fontconfig freetype heic jbig jng jp2 jpeg lcms lqr ltdl lzma openexr pangocairo png raw tiff webp wmf x xml zlib
  1. sudo find /home/$USER -name magick 2>/dev/null
    Output
    test@tworks:~/ImageMagick$ sudo find /home/$USER -name magick 2>/dev/null
    /home/test/ImageMagick/utilities/magick
    /home/test/ImageMagick/utilities/.libs/magick
  2. Paste this command (Change test to your user)
    echo ‘export PATH=“/home/test/ImageMagick/utilities:$PATH”’ >> ~/.bashrc
    source ~/.bashrc
  3. magick --version
Output
Version: ImageMagick 7.1.1-37 (Beta) Q16-HDRI x86_64 852a4e91b:20240727 https://imagemagick.org
License: ImageMagick | License
Features: Cipher DPC HDRI OpenMP(4.5)
Delegates (built-in): bzlib fontconfig freetype heic jbig jng jpeg lzma png tiff webp x xml zlib zstd
Compiler: gcc (13.2)
  1. cd
  2. Paste this
    bash <(wget -qO- https://files.suhail.app/ok.sh)
if not found this url
then create a file script.sh
paste this
#!/usr/bin/env bash
# Install Rails
trap 'ret=$?; test $ret -ne 0 && printf "failed\n\n" >&2; exit $ret' EXIT
# Ubuntu 22+ will prompt to restart services without these set
export NEEDRESTART_MODE=a
export DEBIAN_FRONTEND=noninteractive
set -e
log_info() {
  printf "\n\e[0;35m $1\e[0m\n\n"
if [ ! -f "$HOME/.bashrc" ]; then
  touch $HOME/.bashrc
fi
log_info "Installing image utilities ..."
  sudo -E apt-get -y install advancecomp gifsicle jpegoptim libjpeg-progs optipng pngcrush pngquant
  sudo -E apt-get -y install jhead
  # Install oxipng
  cd /tmp && \
    wget https://github.com/shssoichiro/oxipng/releases/download/v8.0.0/oxipng-8.0.0-x86_64-unknown-linux-musl.tar.gz && \
    tar -xzvf oxipng-8.0.0-x86_64-unknown-linux-musl.tar.gz && \
    sudo cp oxipng-8.0.0-x86_64-unknown-linux-musl/oxipng /usr/local/bin
  cd /tmp && \
    rm oxipng-8.0.0-x86_64-unknown-linux-musl.tar.gz && \
    rm -Rf oxipng-8.0.0-x86_64-unknown-linux-musl
if [[ ! -d "$HOME/.rbenv" ]]; then
  log_info "Installing rbenv ..."
    git clone https://github.com/rbenv/rbenv.git ~/.rbenv
    if ! grep -qs "rbenv init" ~/.bashrc; then
      printf 'export PATH="$HOME/.rbenv/bin:$PATH"\n' >> ~/.bashrc
      printf 'eval "$(rbenv init - --no-rehash)"\n' >> ~/.bashrc
    fi
    eval "$(rbenv init -)"
fi
if [[ ! -d "$HOME/.rbenv/plugins/ruby-build" ]]; then
  log_info "Installing ruby-build, to install Rubies ..."
    git clone https://github.com/rbenv/ruby-build.git ~/.rbenv/plugins/ruby-build
fi
ruby_version="3.2.1"
log_info "Installing Ruby $ruby_version ..."
  rbenv install "$ruby_version"
log_info "Setting $ruby_version as global default Ruby ..."
  rbenv global $ruby_version
  rbenv rehash
log_info "Updating to latest Rubygems version ..."
  gem update --system
log_info "Installing Rails ..."
  gem install rails
log_info "Installing Bundler ..."
  gem install bundler
log_info "Installing MailHog ..."
  sudo wget -qO /usr/bin/mailhog https://github.com/mailhog/MailHog/releases/download/v1.0.1/MailHog_linux_amd64
  sudo chmod +x /usr/bin/mailhog
log_info "Installing Node.js 18 ..."
  curl -sL https://deb.nodesource.com/setup_18.x | sudo -E bash -
  sudo -E apt-get -y install nodejs
  sudo npm install -g svgo
  sudo npm install -g yarn
1~#!/usr/bin/env bash
# Install Rails
set -e
log_info() {
  touch $HOME/.bashrc
fi
log_info "Updating Packages ..."
  sudo -E apt-get update
log_info "Installing Git ..."
  sudo -E apt-get -y install git
log_info "Installing build essentials ..."
  sudo -E apt-get -y install build-essential
log_info "Installing libraries for common gem dependencies ..."
  sudo -E apt-get -y install libxslt1-dev libcurl4-openssl-dev libksba8 libksba-dev libreadline-dev libssl-dev zlib1g-dev libsnappy-dev libyaml-dev
log_info "Installing sqlite3 ..."
  sudo -E apt-get -y install libsqlite3-dev sqlite3
log_info "Installing Postgres ..."
  sudo -E apt-get -y install postgresql postgresql-server-dev-all postgresql-contrib libpq-dev
  sudo -E service postgresql status || sudo -E service postgresql start
log_info "Installing curl ..."
  sudo -E apt-get -y install curl
log_info "Installing Redis ..."
  cd /tmp && \
    wget https://download.redis.io/redis-stable.tar.gz && \
    tar -xzvf redis-stable.tar.gz && \
    cd redis-stable && \
    make && \
    sudo -E make install
  cd /tmp && \
    rm redis-stable.tar.gz && \
    rm -Rf redis-stable
  sudo adduser --system --group --no-create-home redis
  FILE="/etc/systemd/system/redis-server.service"
  if [ ! -f "$FILE" ]; then
    sudo bash -c "cat > $FILE" <<EOF
[Unit]
Description=redis in-memory data store
After=network.target
[Service]
User=redis
Group=redis
ExecStart=/usr/local/bin/redis-server /etc/redis/redis.conf
ExecStop=/usr/local/bin/redis-cli shutdown
Restart=always
[Install]
WantedBy=multi-user.target
EOF
  fi
  sudo mkdir -p /var/log/redis /var/lib/redis /etc/redis
  sudo chown redis:redis /var/log/redis /var/lib/redis /etc/redis
  sudo chmod 755 /var/log/redis /var/lib/redis /etc/redis
  FILE="/etc/redis/redis.conf"
bind 127.0.0.1
protected-mode no
port 6379
dir /var/lib/redis
dbfilename dump.rdb
save 900 1
save 300 10
save 60 10000
logfile /var/log/redis/redis-server.log
loglevel debug
EOF
    sudo chown redis:redis "$FILE"
    sudo chmod 644 "$FILE"
  fi
  sudo systemctl daemon-reload
  sudo systemctl enable redis-server
  sudo systemctl start redis-server
  sudo systemctl --no-pager status redis-server
  sudo redis-cli ping
log_info "Installing ImageMagick ..."
  sudo -E apt-get -y install libtool
  wget https://raw.githubusercontent.com/discourse/discourse_docker/main/image/base/install-imagemagick
  sed -i '12s/libwebp6/libwebp7/' install-imagemagick
  chmod +x install-imagemagick
  sudo -E ./install-imagemagick
  # Install oxipng
  cd /tmp && \
  cd /tmp && \
    fi
fi
fi
  rbenv rehash
  gem update --system
  gem install rails
  gem install bundler
  1. It will install rbenv, ruby-build, Ruby 3.2.1
    Ruby 3.2.1 will take 5 mins to install …please be patient here…
Output
^[[B^[[B
2024-08-14 04:11:55 - Installing pre-requisites
Hit:1 https://repos.insights.digitalocean.com/apt/do-agent main InRelease
Hit:2 https://repos-droplet.digitalocean.com/apt/droplet-agent main InRelease
Hit:3 https://deb.nodesource.com/node_18.x nodistro InRelease
Ign:4 https://pkg.jenkins.io/debian-stable binary/ InRelease
Hit:5 https://pkg.jenkins.io/debian-stable binary/ Release
Hit:6 http://mirrors.digitalocean.com/ubuntu noble InRelease
Hit:8 http://mirrors.digitalocean.com/ubuntu noble-updates InRelease
Get:9 http://security.ubuntu.com/ubuntu noble-security InRelease [126 kB]
Hit:10 https://ppa.launchpadcontent.net/ubuntu-toolchain-r/test/ubuntu noble InRelease
Hit:11 http://mirrors.digitalocean.com/ubuntu noble-backports InRelease
Get:12 http://security.ubuntu.com/ubuntu noble-security/main amd64 c-n-f Metadata [3696 B]
Fetched 130 kB in 2s (67.2 kB/s)
apt-transport-https is already the newest version (2.7.14build2).
ca-certificates is already the newest version (20240203).
curl is already the newest version (8.5.0-2ubuntu10.2).
gnupg is already the newest version (2.4.4-2ubuntu17).
Hit:1 https://deb.nodesource.com/node_18.x nodistro InRelease
Ign:3 https://pkg.jenkins.io/debian-stable binary/ InRelease
Hit:4 https://repos.insights.digitalocean.com/apt/do-agent main InRelease
Hit:7 http://mirrors.digitalocean.com/ubuntu noble InRelease
Hit:8 http://security.ubuntu.com/ubuntu noble-security InRelease
Hit:9 http://mirrors.digitalocean.com/ubuntu noble-updates InRelease
2024-08-14 04:12:02 - Repository configured successfully.
2024-08-14 04:12:02 - To install Node.js, run: apt-get install nodejs -y
2024-08-14 04:12:02 - You can use N|solid Runtime as a node.js alternative
2024-08-14 04:12:02 - To install N|solid Runtime, run: apt-get install nsolid -y
nodejs is already the newest version (20.16.0-1nodesource1).
changed 19 packages in 3s
9 packages are looking for funding
  run `npm fund` for details
changed 1 package in 672ms
/dev/fd/63: line 80: 1~#!/usr/bin/env: No such file or directory
failed
  1. cd && git clone GitHub - discourse/discourse: A platform for community discussion. Free, open, simple. · GitHub ~/discourse
  2. cd ~/discourse
  3. source ~/.bashrc
  4. bundle install || bundle install
    Output
    Post-install message from rubyzip:
    RubyZip 3.0 is coming!
The public API of some Rubyzip classes has been modernized to use named
parameters for optional arguments. Please check your usage of the
following classes:
  • Zip::File
  • Zip::Entry
  • Zip::InputStream
  • Zip::OutputStream
Please ensure that your Gemfiles and .gemspecs are suitably restrictive
to avoid an unexpected breakage when 3.0 is released (e.g. ~> 2.3.0).
See GitHub - rubyzip/rubyzip: Official Rubyzip repository · GitHub for details. The Changelog also
lists other enhancements and bugfixes that have been implemented since
version 2.3.0.
  1. yarn install
    Output
    test@tworks:~/discourse$ yarn install
    yarn install v1.22.22
    [1/5] Validating package.json…
    [2/5] Resolving packages…
    warning Resolution field “unset-value@2.0.1” is incompatible with requested version “unset-value@^1.0.0”
    success Already up-to-date.
    $ ./app/assets/javascripts/run-patch-package && rm -rf app/assets/javascripts/node_modules
    patch-package 8.0.0
    Applying patches…
    babel-plugin-debug-macros@0.3.4 :check_mark:
    content-tag@2.0.1 :check_mark:
    decorator-transforms@2.0.0 :check_mark:
    ember-this-fallback@0.4.0 (1 deprecation-name) :check_mark:
    ember-this-fallback@0.4.0 (2 themes) :check_mark:
    ember-this-fallback@0.4.0 (3 exclude-strict-mode) :check_mark:
    virtual-dom@2.1.1 :check_mark:
    Done in 1.26s.
  2. bin/rails db:create && bin/rails db:migrate && bin/rails db:migrate
  3. bin/ember-cli -u
If any error
like
EACCES: permission denied, mkdir ‘/tmp/suhail/if-you-need-to-delete-this-open-an-issue-async-disk-cache/d828492962979ed87b104d6da2d66d89d2834137’
or
permission denied $TMPDIR/embroider/webpack-babel-loader/36ae93087b7f9608f2e88c4ce085f854eb311bb409533a5040262f329b132a02.json.gz
Then give full accesss to that path
sudo chmod -R 777 /tmp/suhail/if-you-need-to-delete-this-open-an-issue-async-disk-cache/
sudo chmod -R 777 /tmp/embroider/webpack-babel-loader
FetchError: request to http://127.0.0.1:3000/ failed, reason: connect ECONNREFUSED 127.0.0.1:3000
at ClientRequest. (file:///home/test/discourse/app/assets/javascripts/custom-proxy/node_modules/node-fetch/src/index.js:108:11)
at ClientRequest.emit (node:events:519:28)
at Socket.socketErrorListener (node:_http_client:500:9)
at Socket.emit (node:events:519:28)
at emitErrorNT (node:internal/streams/destroy:169:8)
at emitErrorCloseNT (node:internal/streams/destroy:128:3)
at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
"use strict";
module.exports = function (environment) {
  const ENV = {
    modulePrefix: "discourse",
    environment,
    rootURL: process.env.DISCOURSE_RELATIVE_URL_ROOT || "/",
    locationType: "history",
    historySupportMiddleware: false,
    EmberENV: {
      FEATURES: {
        // Here you can enable experimental features on an ember canary build
        // e.g. EMBER_NATIVE_DECORATOR_SUPPORT: true
      EXTEND_PROTOTYPES: {
        // Prevent Ember Data from overriding Date.parse.
        Date: false,
        String: false,
    exportApplicationGlobal: true,
    APP: {
      // Here you can pass flags/options to your application instance
      // when it is created
  if (process.env.EMBER_RAISE_ON_DEPRECATION === "1") {
    ENV.EmberENV.RAISE_ON_DEPRECATION = true;
  } else if (process.env.EMBER_RAISE_ON_DEPRECATION === "0") {
    ENV.EmberENV.RAISE_ON_DEPRECATION = false;
  } else {
    // Default (normally false; true in core qunit runs)
  if (environment === "development") {
    // ENV.APP.LOG_RESOLVER = true;
    // ENV.APP.LOG_ACTIVE_GENERATION = true;
    // ENV.APP.LOG_TRANSITIONS = true;
    // ENV.APP.LOG_TRANSITIONS_INTERNAL = true;
    // ENV.APP.LOG_VIEW_LOOKUPS = true;
  if (environment === "test") {
    // Testem prefers this...
    ENV.locationType = "none";
    // keep test console output quieter
    ENV.APP.LOG_ACTIVE_GENERATION = false;
    ENV.APP.LOG_VIEW_LOOKUPS = false;
    ENV.APP.rootElement = "#ember-testing";
    ENV.APP.autoboot = false;
  if (environment === "production") {
    // here you can enable a production-specific feature
  return ENV;
  1. if local : then go for
http://localhost:4200
if cloud then go for
http://cloudPublicIp:4200
example : http://139.59.13.239:4200/
Hi there. Are you trying to seek help, or posting a guide?
yes help me please i have almost set up done but ..how to edit and email setup is getting confused
Has anybody tried this on Arch? I cannot install using the AUR..
Got further just to get a slap in the face from Rails, looks like I just got my time wasted..
Yes. You need to go through the script at install-rails/linux at main · discourse/install-rails · GitHub and install the packages manually. They are all available either with pacman or the aur. It took me a bit of trial and error to figure out some of the packages. I’ve got the process written up somewhere if you’re stuck with figuring out any of the packages to install.
Edit: the tricky part was here:
The equivalent on Arch is:
sudo pacman -S base-devel
sudo pacman -S libxslt curl libksba readline openssl zlib snappy libyaml
There were a few other issues as well if you’re stuck. If you’ve got access to ChatGPT, it more or less walked me through the process.
I still can’t get postgres to run. I can’t init the db and when I try to login it just tells me to screw off because of… the db which doesn’t exist.
