Botón de publicación en bruto
:discourse2: Summary Raw Post Button will add a button to the post menu. When you click the button, you’ll get a modal / popover with the raw (markdown) version of the post.
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/raw-post-button
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
Settings
Name Description
min trust level Minimum required trust level for the button to be visible in the post menu
Translation Default
button_title Raw Post
There’s only one setting and that setting is min_trust_level
This setting allows you to set a minimum trust level the current user needs to have before they can see that button. It defaults to TL0. Anons will never see it.
Credits
The idea for this component was proposed by @EricGT :+1:
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
43 Me gusta
Awesome.
Now it just needs to work as keyboard shortcut. Since r is not used, I would suggest that.
For those not use to using keyboard shortcuts enter ? when not in edit mode to open keyboard shortcut popup.
2 Me gusta
Per post keyboard shortcuts only work if the post is selected with J / K. When you have a post selected, the R key is already used for reply_to_post. So we need to find a different shortcut for that.
4 Me gusta
Great idea! It’s especially useful to post internal markdown templates for forum staff members in order to use them in wordpress, or any other markdown-“compatible” system.
How about to add a Copy button the the raw post popup?
5 Me gusta
Raw post dark colour isn’t applied in combination with the new Dark Mode setting:
This would be super useful :heart_eyes:, I’m often finding it difficult to copy longer chunks of raw text directly from popup, especially on mobile.
4 Me gusta
Hi there, I apologize for bumping.
What could would I have to edit, exactly if possible, to replace the icon with another Font Awesome icon?
Thanks,
anythingoracve.
There is no admin option to change the icon.
AFAIK the only way to do it would be to clone the GitHub repository, modify the code by either hard coding a new icon, or adding a new option, then use the updated code on your site.
You could also request that as a new feature, but there is no guarantee on when it would be done.
HTH
2 Me gusta
ya que creo que este botón solo muestra la versión sin procesar de una publicación, como https://meta.discourse.org/raw/152542
¡nos falta el TÍTULO de la publicación!
¿no podemos tenerlo como primera línea?
tal vez con un ‘#’ como
# Botón Publicación sin procesar
1 me gusta
Las publicaciones no tienen títulos, los temas sí.
El botón muestra el contenido sin formato de las publicaciones.
No obstante, ¿por qué necesitarías ver el título de un tema en la visualización del contenido sin formato de una publicación?
Haces clic en el botón “raw” (sin formato) en la vista del tema, por lo que ya conoces el título del tema, que siempre está visible en la parte superior de la pantalla.
El título de un tema no se relaciona realmente con el contenido de una publicación. Por lo tanto, no pertenece realmente a una ventana emergente que muestre el contenido “sin formato” de la publicación. Tampoco contiene ningún contenido sin formato para mostrar.
Así que no estoy seguro de cuán útil sería mostrar esta información. :thinking:
2 Me gusta
https://meta.discourse.org/raw/152542 da el contenido sin formato de un tema, no de una publicación.
Los temas tienen títulos.
Y lo necesito porque uso estos contenidos sin formato para hacer copias de seguridad de las versiones en markdown del contenido.
2 Me gusta
