Solucionar problemas de correo electrónico en una nueva instalación de Discourse
You just installed Discourse via the install guide, but email doesn’t seem to work. Unfortunately this means you can’t log in as an admin to finalize the install. :cry: Let’s troubleshootize!
Try the doctor :woman_health_worker:
If you run ./discourse-doctor it will check several ways that your mail configuration might be broken, and offer advice. Try that first.
Did you enter email settings correctly?
The simplest way is to run ./discourse-setup again. Did you enter everything correctly? But wait! If your password has anything other than numbers and letters, you might be better off editing your app.yml with nano or your favorite editor.
You can also double check the settings in your containers/app.yml file. A valid email section looks like this:
DISCOURSE_DEVELOPER_EMAILS: 'name@example.com'
DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: postmaster@discourse.example.com
DISCOURSE_SMTP_PASSWORD: aUd34cdWKCu6CTjfoH7ykk
Closely examine all values for correctness. Note that:
  • it all aligns
  • no leading # characters
  • single quotes around the developer email field
  • password does not include #, ", ', %, ] or other special characters (a # in a YAML value can be misinterpreted as a comment; if you must use special characters, wrap the value in double quotes, e.g. DISCOURSE_SMTP_PASSWORD: "#pass#ord")
If you had any errors in your app.yml and made changes, you MUST rebuild the container for those changes to take effect!
cd /var/discourse/
./launcher rebuild app
Well, you don’t always need to rebuild
Doing a rebuild will often fix things that seem broken, but it takes a while. There are times when a full rebuild is not necessary; the above is usually the best advice, but If you change just SMTP settings, you can do just this to apply them without doing a full rebuild:
cd /var/discourse
./launcher destroy app
./launcher start app
Are your SMTP connections being blocked?
To confirm that your server can indeed contact the email server, issue this command:
telnet smtp.mailgun.org 587
If you can’t connect this way, you’re almost certainly blocked. (And if you do get connected, the escape character for SMTP is ctrl+], then use quit to exit telnet.)
If this happens, first try port 2525, and if that fails, contact your cloud provider support and confirm that your email connections are not being blocked.
What do the Discourse logs say?
From the command line, issue this command:
cd /var/discourse
tail shared/standalone/log/rails/production.log
This will show the last few lines of the log. Look for anything mail related. If you need to view the fuller logs, try
less shared/standalone/log/rails/production.log
To page through the complete log, press space or type GG to jump to the end. Look closely for any email related messages or press /, type email, and hit enter to search.
What do your email provider logs say?
Assuming there are no errors in the Discourse logs, or your Discourse mail configuration, the emails probably went out. The question, is what did your email provider do with them?
Most email providers have a log viewing function. Check the logs for your email domain and see what happened with the incoming emails.
Did you properly set up DKIM and SPF records for your domain?
You must enter those crucial DNS records for DKIM and SPF, otherwise your emails may arrive only sporadically, if at all.
Is the email domain correct?
The default email from address is based on the install domain plus subdomain, so if your URL is discourse.example.com it will be:
noreply@discourse.example.com
But if your mail provider is expecting:
noreply@example.com
.. you may have problems! To get around this, edit and uncomment this exec line in app.yml
#- exec: rails r "SiteSetting.notification_email='noreply@example.com'"
You’ll need to issue a rebuild after uncommenting the above line and setting the from email address as required.
You can also change this from the command line, if needed:
./launcher enter app
rails r "SiteSetting.notification_email = 'discourse@yoursite.com'"
exit
If using Mailgun – have you activated your domain and provided credit card info?
If you are using Mailgun, after you enter your DKIM and SPF records, you must visit https://mailgun.com/app/domains/YOUR.DISCOURSE.DOMAIN.com and click the “Check DNS Records Now” button. At the top of that page you should see “State ACTIVE” (in a calming green). If it says “State Unverified” (in a scary warning-yellow) Mailgun will not accept mail.
Mailgun now requires a credit card in order to deliver mail (other than to you). If your mailgun logs have a message about “free accounts,” this is your problem.
Other mail services have similar requirements.
Are you using an IP address as the mail domain?
This does not work in our experience. You must use a domain name when sending email, not an IP address like 192.168.1.1.
If you really want to go on with an IP address, try mail settings similar to these:
DISCOURSE_SMTP_ADDRESS: 172.17.0.1         # e.g. use internal docker IP here
DISCOURSE_SMTP_USER_NAME: "YOUR-SMTP-USER-NAME"
DISCOURSE_SMTP_PASSWORD: "YOUR-SMTP-PASSWORD"
DISCOURSE_SMTP_ENABLE_START_TLS: true     # (optional, default true)
DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: none
DISCOURSE_SMTP_DOMAIN: example.com
Need to log in without receiving a registration email?
We don’t recommend this, because your email is still broken, and you have a broken Discourse until email is working. But if you absolutely must log in as admin with email broken, here’s what to do:
cd /var/discourse
rake admin:create
And answer the prompts. It takes a few seconds before they appear. When it asks for the password, you will not be able to see what you type. That is why it makes you type it twice.
Email smtp port selection (Using 465?)
The ability to be able to AUTH using ‘telnet’ is extremely important in your first steps of email troubleshooting.
Port 465 (SMTP over SSL) uses implicit TLS. If you need to use port 465, add this to your app.yml:
DISCOURSE_SMTP_PORT: 465
DISCOURSE_SMTP_FORCE_TLS: true
You may also need to try alternate ports such as port 2525 or port 587 (Mail Submission) when things do not seem to work as expected.
Command Line SMTP tests for experienced sysadmins
If you’re comfortable with the command line, these might help diagnose network or certificate problems. If these do not seem “easy-to-follow” then you should please ignore this section.
See also Test SMTP authentication and StartTLS - Sysadmins of the North.
Office 365 Tweaks
If you’re using Office 365, be sure to include these (the first line is what you are likely missing):
DISCOURSE_SMTP_AUTHENTICATION: login
and set the correct value for DISCOURSE_NOTIFICATION_EMAIL (which is likely different from your forum hostname).
TLS and SSL issues
By default, Discourse uses STARTTLS to encrypt its connection to the email server. Some email servers (increasingly rare nowadays) don’t support this or aren’t configured to use it, so it can be disabled by adding this line:
DISCOURSE_SMTP_ENABLE_START_TLS: false    #default: true
Other email servers might support STARTTLS, but use a self-signed certificate. This is uncommon and can be enabled with:
DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: none #default: peer
Email still doesn’t work! What next?
Anything else I forgot here? Feel free to edit this.
Debug issues with first connection to smtp server from inside the Discourse container
1. Enter your container:
2. Check dns resolving for your smtp server name via getent hosts:
(dig, nslookup, ping etc. are not installed inside the container.)
getent hosts your.smtp.server
On success, it will look like this or will be blank on failure.
# IPv4
123.123.123.123 your.smtp.server
# IPv6
2001:db8:0:0:0:ff00:42:8329 your.smtp.server
3. Try to open a connection to your smtp server via openssl:
(telnet, nc etc. are not installed inside the container.)
Fiddle with some different settings until you succeed with a connection.
openssl s_client -connect your.smtp.server:465
openssl s_client -connect your.smtp.server:587 -starttls smtp
# IPv4
openssl s_client -connect 172.17.0.123:465
openssl s_client -connect 172.17.0.123:587 -starttls smtp
# IPv6
openssl s_client -6 -connect "[2001:db8:0:0:0:ff00:42:8329]:465"
openssl s_client -6 -connect "[2001:db8:0:0:0:ff00:42:8329]:587" -starttls smtp
See: How to check SMTP connection → Step 3: Checking SMTP Connection Over TLS Using Openssl
4. Use your found working connection settings with Discourse.
:rocket:
Bonus: show Discourse IP from inside docker container
( ifconfig , ip etc. are not installed inside the container.)
hostname -I
Result like:
172.17.0.2
57 Me gusta
I am not getting any emails
Unable to send email
Mail system not working even thought I tested it with telnet and other platforms
Post Install Email Issues
Installing Discourse on DigitalOcean - got stuck
Activation email not being delivered, test email working
Announcing Discourse Doctor
Recommended SMTP provider
Discourse SMTP not receiving mails?
After Installation Discourse is unable to send Verification email
No activation email
Mail error 504 5.7.4 Unrecognized authentication type
Not Receiving Email for Admin Creation
Trouble setting up smtp
Mail server setup
Discourse and MailJet issue
All files and directories disappeared from root
Email not sending
Emails Failing to Send
Discourse SMTP Error
Email installation issue
SMTP do not work
Post Install Can't complete email verification
Errors with Sidekiq - emails not sending
My Discourse is not sending emails
Unable to find verification email
MKJ's Opinionated Discourse Deployment Configuration
Email not sending after update
Database shut down error at the end of discourse docker setup
E-Mail not working after moving to self-hosting and adding DKIM record
Email not working with 123-reg and discourse on hosted Virtual Private Server - all other aspects appear to
New users not receiving activation emails
SMTPAuthenticationError: 535 Incorrect authentication data
Issue on Discourse Digest Email
How do I change my primary email
Letters are not sent. What to do?
Sidekiq email errors and settings issue
Noob installation : email not working, trouble with the digitalocean console
SMTPAuthenticationError From Discourse-Doctor On New Install
Outgoing/incoming email changes for our hosted customers
Any MailJet alternatives?
Mail subdomain problem
Activation Not send
Email jobs failing after latest update, certificate verify failed (unable to get local issuer certificate)
Problems with email
Email not working (SSL_connect returned=1)
Email Hostname Certificate Mismatch Causing sidekiq Queue Overload, Severe Site Instability
Zoho Mail problems
Cant setup admin account
Understanding mail concept
How to resend activate email when I close the tab
Unable to send email from my forum
Site installed but NO admin email activation
Emails automatically generated from the forum are not working. Any ideas?
./launcher start app - does not run (need to re-setup SMTP)
UNEXPECTED ERROR Net::SMTPAuthenticationError
Discourse-app container starts then silently stops
Fresh Discourse/Docker install wont send mails
I don't receive the activation email to log in as an admin
Discourse install and SMTP issue
Cannot send email - problem with port 465
Will ./launcher destroy app && ./launcher start app remove the built Docker image?
Trying everything, no luck with smtp working
MailJet SMTP is Not Working
SMTPAuthenticationError - I don't receive mail from mailgun to setup the admin account
My forum does not send emails
SMTP problem with Amazon SES
I dont know whats wrong with the SMTP service
Problem when updating Discourse Forum
ERROR – 535 auth failure
Troubleshooting Outgoing Email
Backup installation problem?
Yet other SMTP 587 port email various errors
Reset password at command line
Some people are unable to complete the registration, the activate button does not work or the email does not arrive
New setting up and SMTP is not working
Emails not arriving on Gmail
Struggling to Configure SMTP in Discourse with Azure Communication Service
501 5.5.4 You are not allowed to send from this address
When i use email :timeout?
Activation Email Not Received for Discourse Admin Account, After Registering User in The Forum
Restore a backup from the command line
Unable to Send Admin Emails After Forum Installation
Can't Send Emails
Trouble with Email Verification After Discourse Installation
Issue with setting up email: Job exception: Net::SMTPAuthenticationError
:cn: Discourse Official Install Guide | Discourse 云平台安装
Getting up Brevo correctly with Discourse
Cheapest way to run Discourse?
How to change this email
Discourse + DigitalOcean + Mailjet setup
Email for completion not sending because smtp are not correct
Connect SMTP to Discourse
SMTP Mails don't send and connection fails, but openssl works
Issue with creating admin account for first time
ReadTimeout error (No solution)
Confusing email documentation
Users don't get confirmation e-mail
How Do I Set Up the E-Mail SMTP Server Required for Discourse?
Initial Activation email Not sent. What's wrong with this yaml?
Not Receiving Emails After Successful SMTP Configuration with Neo.Space
Email does not work; Net::SMTPAuthenticationError
What can I do when my users stop receiving verification emails?
Flarum to Discourse Migration with users and discussion
Editing Mail Server
Outlook SMTP Not Working
How to set domain value in Email -> Server Settings
Trouble sending mail via Namecheap Private Email (SMTP) on self-hosted Discourse
Who can help me ? Thanks!有没有人愿意帮我解决一下邮箱问题?
GMail delivery problems: is subdomain discourse.ourdomain.org strictly necessary in outgoing mails?
Not Receiving Admin Verification Email After Setup
Latest version of Discourse not sending Email
Persistent SMTP Timeout Issue with Spacemail on Discourse (VPS, Docker)
Email delivery configuration checklist
How to change Discourse email settings after installation
Deploy Discourse without Docker
./discourse-setup puts SMTP username at start of SMTP password
[Résolu] Please les modalités simple pour modifier smtp_password
How do I create Discourse forum with docker and VPS?
无法收到邮件的问题
新安装的discourse无法使用网易邮箱发送验证邮件?
Moving from Mailgun to Amazon SES as an amateur
Email don't send
Editing posts cause notification
Activation email on Spam
Installation success but no email
Admin activation E-Mail not sent on fresh self-hosted install (ubuntu 20.04)
Problem with changing password from mail
Problème de réception du mail de confirmation admin (installation sur Hostinger)
Discourse on Azure VM
Email not sending - Domain Spoofing Prohibited
DNS - NameCheap - Mailchimp - sanity check please
How can I change this? smtp
Waiting the activation email, been hours still not received
Not getting activation email
I have a question about configuring the mail system
Connecting to a SMTP server on localhost:25 without auth?
SMTP error: Must issue a STARTTLS command first
I have a problem that needs help because the Email can't be sent
Email for new user not sent
How might we better structure #howto?
Mail doesnt work after installation
Not receiving confirmation email
I did not receive an email to activate my account
Emails are not sent
New signups not receiving welcome email
Discourse with other websites, SMTP issue: End of file reached
Setup wont send me the email
Siteground email
Update failed - Not starting
Email config help
404 Error after installaton
List all users with a given email domain
I created a droplet to install Discourse, what should I do next?
New install email not working "shadowed so this will be ignored"
¿Es esta información está actualizada? No me funcionó; tuve que reconstruir la aplicación después de cambiar el puerto SMTP.
2 Me gusta
Si discourse-doctor indica que la conexión al puerto 587 falló, pero openssl s_client -connect your.smtp.server:587 -starttls smtp funciona correctamente, prueba esto, ambos comandos deberían tardar la misma cantidad de tiempo:
time openssl s_client -starttls smtp -connect your.smtp.server:587 </dev/null > /dev/null
docker run --rm discourse/base:2.0.20231023-1945 bash -c 'time openssl s_client -starttls smtp -connect your.smtp.server:587 </dev/null' > /dev/null
Si la versión de docker tarda mucho más, es posible que tengas una configuración incorrecta en tu archivo /etc/docker/daemon.json. Puedes intentar poner el servidor de nombres de Google en primer lugar:
  "dns": ["8.8.8.8", "ww.xx.yy.zz", "ww.xx.yy.za"]
el puerto 2525 funciona para mailjet.
587 falló.
2 Me gusta
Edité el OP para sugerir el uso del puerto 2525. Es su servicio de alojamiento el que bloquea el puerto. Debido a eso, muchos servicios de correo también admiten el 2525.
3 Me gusta
Oye, solo quería añadir una nota sobre esto;
Mailgun ahora requiere una tarjeta de crédito para poder enviar correos (que no sean a ti). Si tus registros de Mailgun tienen un mensaje sobre “cuentas gratuitas”, este es tu problema.
Me registré esta semana (julio de 2024) y hasta ahora, funciona sin tener que añadir una tarjeta de crédito, utilizando el nivel gratuito básico. Basándome en lo que he visto en hilos antiguos de foros, parece que han estado cambiando de opinión sobre esta política, y el uso y las limitaciones de sus niveles gratuitos, quizás
1 me gusta
Vaya. Eso es una locura y muy diferente a como han sido las cosas durante mucho tiempo.
Ha sido muy difícil para la gente averiguar cómo cambiar al plan de pago por uso y no suscribirse a un plan mensual bastante caro.
¿Has enviado a otros usuarios además de a ti mismo?
1 me gusta
Sí, he enviado a los usuarios y está funcionando. El único inconveniente es que, por alguna razón, las direcciones de correo electrónico de AOL están bloqueando mis correos electrónicos, pero no creo que sea culpa de MailGun. Estoy tan sorprendido como tú :slight_smile:
Actualización: parece que la razón por la que algunos correos electrónicos están siendo bloqueados es porque la IP utilizada para enviar los correos electrónicos gratuitos de MailGun es compartida, por lo que ha sido reportada como “Spam” por algunas plataformas de correo electrónico como AOL, Yahoo Mail y otras. Parece que todos los que no usan Gmail están experimentando rebotes o rechazos en la entrega de correos electrónicos.
1 me gusta
¿Puedes explicarme cómo revisar la configuración en nuestro archivo containers/app.yml? Los novatos no sabemos cómo hacer estas cosas sin instrucciones explícitas. lol
Si no sabes cómo usar una herramienta como nano, vuelve a ejecutar discourse-setup. Después de que guarde los cambios, puedes presionar Control+C y luego
./launcher destroy app;./launcher start app
1 me gusta
ok, pero ¿cómo reviso la configuración en mi archivo containers/app.yml para poder ver la sección de correo electrónico y verificar que los datos son correctos?
Si no te gusta mi respuesta, puedes buscar “nano” en Google.
Podría decirse que el OP debería decir algo sobre nano, aunque, como dije, si no sabes qué es, simplemente vuelve a ejecutar discourse-setup, ya que lee los valores del archivo y no puedes estropear el formato.
Ya veo lo que quieres decir ahora. Cuando ejecutas los comandos destroy y luego start, muestra los datos que necesito una vez que se completa. ¡Mis disculpas! :slight_smile:
1 me gusta
Ejecuté al doctor y obtuve un error que dice SMTPAuthenticationError. El doctor luego dice que este no es un error común y que no tienen sugerencias sobre cómo solucionarlo. Si esto sucede, asegúrate de verificar dos veces tu nombre de usuario y contraseña SMTP, ya que el proceso de configuración de Discourse no te dice si es incorrecto, simplemente no funciona (no envía correos electrónicos) y te deja perplejo. Algunas cosas que hice y que ayudaron fue conectarme por SSH a mi servidor usando Ubuntu en lugar de LISH (porque estoy usando Linode) porque LISH tiene muchos errores y no admite copiar y pegar. Luego rehice el proceso de configuración y copié y pegué todo esta vez en lugar de escribir contraseñas de 100 caracteres, jajaja. De todos modos, ¡espero que esto ayude a algunos de mis compañeros novatos!
Tu nombre de usuario o contraseña son incorrectos.
No estoy seguro de por qué no logré solucionarlo, pero el error se explica por sí mismo.
Podría ser que lo hayas copiado y pegado mal. Podría ser que tenga caracteres que necesiten ser escapados.
Utilizo Brevo como mi remitente de correo electrónico de notificación, pero cada notificación enviada fue rechazada debido a un error. Encontré un mensaje en Brevo que dice: “El envío ha sido rechazado porque el remitente que utilizaste no es válido. Valida tu remitente o autentica tu dominio”. Debido a esto, mi foro no puede funcionar en absoluto. Me pregunto cómo solucionar esto: ¿qué tipo de remitente necesito? ¡¡¡Muchas gracias!!!
Para la dirección del remitente, se puede configurar en el subdominio de correo que estás utilizando para enviar correos, como correo@dirección_dominio.
Para autenticar el subdominio + remitente, hay algunos pasos para los que tienen una guía aquí:
Hola gente de Discourse.
He estado luchando durante varios días para configurar los parámetros de correo electrónico con el puerto 465, y la solución no está aquí ni en ninguna publicación que haya leído en el foro (y he buscado mucho).
Por supuesto, es una cuestión de lo que acepta su servidor de correo. En mi caso, solo 465 sobre TLS.
Las dos líneas de configuración requeridas para agregar en app.yml son:
Algunos detalles
La configuración predeterminada resultó en un error Net::ReadTimeout al intentar un correo electrónico de prueba con discourse-doctor. Enviar correos electrónicos de prueba desde dentro del contenedor funciona bien con, por ejemplo, curl, exactamente como en esta publicación que me llevó a la mitad de la solución: Cannot send email - problem with port 465 - #10 by schungx
Solo pude averiguar la segunda configuración después de mirar el contenido de app.yml y modificar este parámetro. Tengo la sensación de que la mayoría de los programas (por ejemplo, Thunderbird) establecen implícitamente el protocolo correcto al seleccionar el puerto 465, ¿entonces tal vez Discourse debería hacerlo? Esto parece ser realmente estándar, también como se destaca aquí:
(enlace a la publicación completa)
Así que realmente defendería la actualización de la sección de esta guía sobre el puerto 465 o hacer que discourse-setup elija automáticamente la mejor configuración.
3 Me gusta
Normalmente no comento sobre nada, ¡pero eso fue realmente útil!
Gracias, el mantenedor de Discourse debería incluir esta configuración en la configuración predeterminada, quiero decir, fue tedioso configurar su software, aún así no tengo nada que criticar, excepto que en un proyecto tan grande alguna información no está disponible rápidamente y alguien debería “profundizar”.
¡OK, funciona para mí!
Se fusionó una publicación en un tema existente: Uso de % en la contraseña SMTP para discourse-setup
