Een bericht bewerken brengt me vele berichten terug (redux)
Previously
Today I just edited post 135 in a thread and it took me back 20 posts (as previously reported) but the post number at the bottom said 134/135.
After editing I saw this:
Going to the bottom to see the post I was editing (135) showed this:
The post it showed me was actually 115:
So to be clear what are the repro steps?
Good question.
I’m still trying to reproduce it. Trying to remember if I did anything in particular during this edit.
A normal edit works OK.
This is also happening when editing a DM in a long DM thread.
Ok, so what are the specific repro steps?
The same as the old closed issue linked in the OP, but for DM view rather than Topic view.
I’m also still seeing the original linked issue after editing a post. Same repro steps.
retrogameboards.com running 2.8.0beta2
Just confirming, this issue is specific to Safari iOS? Does not happen in Firefox / Chrome?
This is still happening BTW.
I have experienced this as well, though I don’t have a specific repro.
I’m still getting this. First reported in 2020.
Help me Obi-wan
Still getting this.
It’s so annoying, like a scratch on a vinyl or CD that makes the audio skip back a bit. Then you have to find your place again.
Still happening :upside_down_face:
Hallo!
Ja, dit gebeurt nog steeds.
Hmm, could this be somehow related to:
Lijkt een goede kans
Onwaarschijnlijk, omdat de code voor die bug werd geïntroduceerd nadat deze voor het eerst werd gemeld.
I have a nagging bug for a long time when opening/closing topics that are assigned. It’s a much narrower use case, very much not what the report here is about, but there’s a slim chance the underlying issue is the same.
Here’s the PR for the other issue: DEV: Fix a rare bug where topic scrolls to OP unexpectedly by pmusaraj · Pull Request #34713 · discourse/discourse · GitHub, its repro steps are quite different, they’re related to the assign plugin (PR has specifics). But maybe, maybe… the fix can do something for your use case as well. One can always hope!
Ik kan niets met deze informatie. Maar ik ben hoopvol
Anything I can do to help get this one licked?
It’s the final boss of bugs.
Hurrah! I can repo on demand on a certain forum.
  1. Reply on a thread
  2. Compose some reply
  3. (Confirm you are at the bottom of the thread)
  4. Click discard
  5. Confirm discard
  6. BOOM, you are somewhere high up the thread
works on:
doesn’t happen on:
So I guess this means it was fixed in a recent update and the forum is on an old version?
