“BBCode-lite” without the need to install a plugin …
Adds a simple control (palette icon) to the Composer to facilitate colouring of the foreground and background of text
Select a word or text
Hit the palette control
It will be wrapped like so: [wrap=color color=# bgcolor=#]word[/wrap]
Replace the #s with html-compatible colour names, e.g. “red”, “grey” … experiment.
NB Same caveats apply as to BBCode: can be used to hide text.
Credits
18개의 좋아요
Thanks a ton for this useful little component.
It doesn’t seem to be applying the composer.color_ui_button_title properly, both when left at the default or when customized:
1개의 좋아요
Hello there. I don t have color text button like on this foto. Here I don t see too.
Moin
2월 9, 2024, 11:36오전
4
이 Customization > Theme component 은 여기에 설치되어 있지 않습니다. 그래서 버튼이 표시되지 않습니다.
사이트에 추가하셨나요?
Robert:
If I knew how to add a plugin it would be good.
Moin
2월 9, 2024, 11:50오전
7
There is a guide how to Installing a theme or theme component
All the information is part of the table in the first post
3개의 좋아요
Excellent component!
Bug report: If I click the palette button with no text selected, it inserts the translation descriptor instead of the ‘default text’:
[en_GB.composer.color_ui_default_text]
isn’t found in the site text customization menu, and isn’t on the component settings page.
2개의 좋아요
Canapin
(Coin-coin le Canapin)
12월 30, 2024, 1:55오후
11
Clicking the palette icon without having text selected output this:
[wrap=color color=# bgcolor=#][en.composer.color_ui_default_text][/wrap]
Is this a missing string?
3개의 좋아요
Canapin
12월 30, 2024, 6:47오후
13
I didn’t even read the last message
3개의 좋아요
nathank
(Nathan Kershaw)
12월 30, 2024, 10:20오후
14
Awesome work @merefield ! This has been a sorely missing feature - until now!
I wonder if this could be combined with this TC to have a single super-awesome BBCode TC:
This theme component adds few formatting options in the composer : underline, align center, align right, justify and strikethrough. You can customize the text of each button in the settings, making it compatible with every languages. Exist in rtl version (change align right to align left).
4개의 좋아요
