yanokwa
(Yaw Anokwa)
April 18, 2024, 10:47pm
1
In highlighted languages in Settings, if you click on the link https://highlightjs.org/static/demo , it takes you to https://highlightjs.org/not-a-cdn which says…
Do not use us as a CDN. You should not be linking to any assets that are hosted on our website. We are getting million of garbage requests due to this misuse of our assets.
Perhaps the link should be https://highlightjs.org/demo
I believe the relevant string to be changed here (but will need changing in other languages).
max_prints_per_hour_per_user: "Maximum number of /print page impressions (set to 0 to disable printing)"
full_name_required: "Full name is a required field of a user's profile."
enable_names: "Show the user's full name on their profile, user card, and emails. Disable to hide full name everywhere."
display_name_on_posts: "Show a user's full name on their posts in addition to their @username."
show_time_gap_days: "If two posts are made this many days apart, display the time gap in the topic."
short_progress_text_threshold: "After the number of posts in a topic goes above this number, the progress bar will only show the current post number. If you change the progress bar's width, you may need to change this value."
default_code_lang: "Default programming language syntax highlighting applied to markdown code blocks (auto, text, ruby, python etc.). This value must also be present in the `highlighted languages` site setting."
warn_reviving_old_topic_age: "When someone starts replying to a topic where the last reply is older than this many days, a warning will be displayed. Disable by setting to 0."
autohighlight_all_code: "Apply syntax highlighting to HTML-authored <code> blocks, even if they didn't specify a language. To configure markdown-authored code blocks, use the 'default code lang' setting."
highlighted_languages: "Included syntax highlighting rules. (Warning: including too many languages may impact performance) see: <a href='https://highlightjs.org/static/demo/' target='_blank'>https://highlightjs.org/static/demo</a> for a demo"
show_copy_button_on_codeblocks: "Add a button to codeblocks to copy the block contents to the user's clipboard."
embed_any_origin: "Allow embeddable content regardless of origin. This is required for mobile apps with static HTML."
embed_topics_list: "Enable the embedding of topic lists in HTML format. This setting allows you to incorporate lists of topics from your forum into other websites in a compatible and easy-to-use manner."
embed_set_canonical_url: "Set the canonical URL for embedded topics to the embedded content's URL."
embed_truncate: "Shorten the contents of posts that are embedded from external sources. This setting ensures that only the initial part of content is displayed when a post from an external URL is embedded on your site. If you prefer to display full content from the external posts, you can disable this setting."
embed_unlisted: "Embedded topics will be unlisted until a user replies."
import_embed_unlisted: "Imported embedded topics will be unlisted until a user replies (even when the `embed unlisted` site setting is unchecked)."
embed_support_markdown: "Support Markdown formatting for embedded posts."
allowed_embed_selectors: "A comma separated list of CSS elements that are allowed in embeds."
biocrusoe
(Michael R. Crusoe)
November 11, 2024, 9:42am
3
I sent a PR to fix this, thank you for tracking down the code location: https://github.com/discourse/discourse/pull/29701
Moin
November 11, 2024, 9:48am
4
The only file you need to change is server.en.yml. The other ones are changed when translations from Crowdin are merged.
https://github.com/discourse/discourse/blob/61a4229dafdf67a4154ecae7286026360d8e4827/config/locales/server.ar.yml#L1-L5
pmusaraj
(Penar Musaraj)
November 11, 2024, 7:42pm
5
PR is now merged, thanks @biocrusoe , and thanks for reporting @yanokwa . Closing.
