The Discourse team launched a sidebar design experiment called “Sidebar Feng Shui” to create a more spacious, serene layout by increasing padding and margins, aiming for visual clarity at the cost of potentially pushing content below the fold. Initial reactions were mixed: nat and manuel praised the cleaner look, while Jagster and Oogiem found it too sparse. Moin highlighted usability issues on tablets, especially regarding visibility of DMs and top sections, and noted the chat button’s space consumption. awesomerobot offered detailed critiques — excess bottom spacing, reduced heading prominence, ambiguous clickable areas, and misaligned scrollbars — suggesting global padding adjustments for visual harmony. markvanlan proposed sticky section headers to improve navigation. In response, chapoi confirmed scrollbar fixes and explained the intentional removal of hover effects on collapsible headers to distinguish them from navigational links. Moin later noted a small improvement after a link removal freed up space. Despite dissent, the team decided to merge the experiment into core, citing it as a better default for diverse users, while offering CSS variables (e.g., --d-sidebar-row-height) for customization. The discussion underscores tension between aesthetics, usability, and screen real estate — especially on mobile — and hints at future solutions like contextual menus or nested sidebars.
We are running an experiment on meta that applies some tweaks to the sidebar design to create a more spacious and serene layout. By increasing the spacing between elements, and optimising padding and margins, we’re aiming for a cleaner and more organised appearance, however at the cost of more elements potentially disappearing beneath the fold.
Though, what this makes evident in chat on desktop is that if you’re part of many channels, it’s quite a bit of scrolling to see any new unread messages.
Yes for sure, at some point it starts to make sense to use the forum/chat switcher when using fullscreen chat I think. This design def brings you to that point faster.
It’s not only a matter of taste, but probably also of screen size.
On my tablet, I usually collapse most of the sections, so I can still see when the person to whom I have sent a chat message is online in chat. Therefore, the DMs section has to be visible. But I also use the top section a lot, so scrolling to the bottom once does not fix it.
As you can see, even if all sections are collapsed, it doesn’t work to see DMs and the top section with the additional space, whereas I was had space to open some sections before.
Agree about the space.. why not drop the button actually and use the same contextual switch as the admin menu or Documentation on meta?
With respect to the length of the sidebar in general, it seems it’s falling victim to it’s own success already? There’s just so much stuff to put there.. it often makes sense to have a custom section (or several), members can also put their own sections, then there’s the lists of categories, tags, messages, chat.. And you have that menu that doesn’t stop scrolling, no matter the screen estate.
Maybe just have contextual menus all over? To me they have a much nicer flow than collapsing sections.
It does look cleaner, but I share the concern about screen space, especially on tablets and smartphones. From a gut feeling: maybe something right in the middle between the current and the proposed design.
Also: when the sidebar is updated that way, it immediately makes the list of posts on the right side look too crowded. I think these two would need to be aligned (there is already more mismatch than I personally like since the increase of the base font size).
Is the smaller “all categories” “all tags” intentional? those are fairly important links IMO
Generally heading text feels tiny, especially when collapsed
Not a fan of the carets on the right, I guess this is meant to differentiate headings, but it feels like we’re wasting space when we’ve already got a sidebar column for icons
The right padding should be removed from the sidebar container so the scrollbar is flush right like Manuel mentioned
We lost the background hover effect on headings… this combined with the smaller size makes the clickable area feel a lot more ambiguous than the main links
Yes, tbh this feels so padded that it feels out of place with the rest of Discourse… for this to be default I think we’d need to commit to adding more padding everywhere (not opposed to this, but it’s a big effort)
yeah we’re considering adding a sidebar to the sidebar, kind of like what slack does… this could switch contexts and sidebar content, right now we have a few diverging approaches to how sidebars work and need to tie them together one way or another. We could also move messages and “about” content to their own sections to make the main sidebar shorter.
What would help me the most is if the section header stuck to the top while scrolling. I have many categories and chat channels in my sidebar and with this change it’s harder to quickly understand where I am, because often the heading is scrolled off the page.
If we implemented sticky section headers (like we do for user avatars on post on scroll) I think I’d like this a lot more
Can you give this another go, see how it feels. We’re on V2 already
Oversight on my part, thank you – should be fixed.
On purpose. I wanted the headings, which only collapse, to be distinct from the other elements, which navigate somewhere. I found the full hover effect on a collapsable header to be a bit unusual. Plus, there are 2 actions for most rows: the collapse and the secondary action (edit or add for messages). Highlighting the whole row, including the secondary action, felt off.
Personally I am much happier with dense tight text with very little white space. Even the before layout seems wasteful of space. After is worse. Too bad it can’t be a user setting.
We decided to merge the current status of the design experiment into core.
There already are some easy-to-use variables in place to modify this to your liking (notable --d-sidebar-row-height) and it’s easy to further strip away spacing, for those who prefer that; however we find this to be a better default to offer to the range of users we have at Discourse.
