My 2FA app doesn’t recognize Discourse, and I need to input the data myself before I can add the code. What algorithm is the 2FA? Is it HMAC SHA 1?
Yes. The equivalent oathtool command is
oathtool --totp -b «TOTPCODESTRING»
What are you using that it doesn’t recognise Discourse (presumably, it doesn’t recognise the QR code)?
Does it work with this?
