Как создать боковую панель, похожую на боковую панель документации Meta?
Hi everyone,
I have just joined the discourse community and had a question to ask.
I have self-hosted discourse, but the sidebar is not as cool as the new discourse sidebar for documentation.
How can I create one or is it already available as a component or plugin?
Thank you so much.
Welcome to Meta :wave:
The plugin you are looking for is
2 лайка
@Moin I am getting this error at the end after this command ./launcher rebuild app.
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean' failed with return #<Process::Status: pid 317 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"yarn", "cmd"=>["if [ \"$version\" != \"tests-passed\" ]; then\n  rm -rf app/assets/javascripts/node_modules\nfi", "su discourse -c 'yarn config set network-timeout 60000 -g'", "su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'"]}
777664b8ad6441b3a3463638d286f3677b3b5ab3fac4fa17b41a7de5e5886628
Can you help me with this?
You need to look for earlier errors.
2 лайка
