Center Category Logo
Hello,
I have searched and haven’t found how I can center the Category logo that is above nav while viewing the Category page?
Thanks.
You mean a category page like this?
It looks like you have a trial on our Starter plan, which doesn’t allow custom themes. You’d have to be on our Standard plan to do something like this.
With a custom theme you’d do this by adding CSS like this:
.category-heading {
  display: flex;
  flex-direction: column;
  align-items: center;
to get an outcome like this:
Perfect! Thank you! Where can I find documentation on properties such as display, flex-direction, etc? Looking to add a BG color too.
This link may help get you started with CSS
You can also look for #theme-component that do what your looking for. They can also be a good resource to look over the code in GitHub to copy code from.
The Mozilla Developer Network tends to be of better quality than W3Schools: MDN Web Docs
Awesome thanks will have to look over this one.
