The text in codeblocks seem small er than usual. For multiline codeblocks, the line spacing between lines also seem less.
Was something changed?
For example:
Recent update will see if can find link — found it in Daily Summary
This screenshot doesn’t give any information on the font-size compared to other texts.
Are you sure?
The code highlight file hasn’t changed since the last improvement linked by Dan:
That was an old screenshot, and is cropped.
Actually, it seems to be on mobile, not desktop.
I looked at the font-size on both mobile and desktop, and they have the same value (.875em) ![]()
