אירוע חוזר "going" לא נמחק יותר
Hello,
when users click “going” for a weekly repeated event, normally their votes disappiered right after the event and you could always see the new votes for next week. Now they accumulate to a Long list.
I might have changed some configuration about the visibility of events but I do not find it to reset it.
Any Idea, thank you
Ann
Maybe I need to describe it better:
  • you have a weekly repeated event Monday evening 7-8pm
  • some people have clicked going, interessted or not coming and this is shown by the respective symbol on their listed avatar
  • next Monday at 8:01pm all those symbols are gone, avatars stay listed but greyed out
  • event topic then shows date of the Monday one week later and nobody “going” etc until the first users click again
Now I fiddled around with some visibility setting that the ones attended today are longer visible then 8pm or that the event is not deleted or anything like that…
But now their avatars are never reset and greyed out but all “going” participants are accumulated over weeks and shown as actively “going”
I can’t find the setting to make it the same as before, at 8pm the event is cleared and set to next week without any participants
Any hint where I can revert this?
And yes, I know, document your changes :slight_smile:
Hi Ann — sorry for the delay here, but thanks for reaching out about this! You’re right, this was a recent change to RSVP to the current and future instances of recurring events. We’re discussing this internally to see how we might improve upon this further. I’ll follow up with more information once I have something to share!
Hello @lindsey ,
do you have further information on this topic?
At the moment we are exporting the event to see who changed their state when and then remove them from the list manually.
That’s a bit of a hassle.
Thank you for any update
Hi @anko127 — thank you for following up! I can appreciate how much of a hassle this manual effort has been, and we definitely want to fix that up for you.
Our plan is to improve recurring events to allow people to choose whether they are RSVPing to the single upcoming event, or to every event in the series. We’re finalizing the design work now and then we’ll be getting this worked in front of our engineering team. I don’t have an ETA on when it will be fixed, but it will be in our “next up” projects so I should be back with an update soon.
יש חדשות כאן? תודה
Hello @lindsey ,
Do you have any update on this topic?
To Reset the participants list when the Event has passed.
Thank you
I’m afraid I don’t have an update for you, @anko127 — this is still in our backlog but we have not yet prioritized it for development. I’ll discuss with the team to see when we might be able to pick this up.
I think it was working when I startet using Discourse prior autumn 2024, could it just be a misconfigured setting like keeping History for the Event?
We are experiencing exactly the same issue described above.
In our community we run many recurring events (support groups, body doubling sessions, regular meetings). Because the participant list for recurring events is not reset, the list quickly becomes inaccurate and continues to grow over time. After a few weeks it no longer reflects who is actually attending a specific occurrence of the event.
This creates a lot of confusion for both organizers and participants.
Another problem for us is that the people who create and organize these events (group facilitators) cannot remove participants from the list. Even when we assigned category moderator permissions to them, they still cannot manage the attendee list. Only global moderators or admins seem to be able to remove participants.
Since we have many groups organizing their own events, it is not practical for admins to manually manage all participant lists.
For communities like ours that rely heavily on recurring events, this makes the RSVP functionality very difficult to use.
Are there any updates or plans to improve how recurring event attendance is handled?
I’m not 100% sure what is but it looks like this was indeed the intended behavior for recurring events. @j.jaffeux do you remember the use cases for not reseting “going” participants on recurring events? Like our weekly team calls?
Will be fixed by
Because we don’t have per date event entry I think.
Hi there,
Thank you for looking into it.
But this sounds like “ Working as designed, no bug” or are you still investigating how to provide this automatic reset after event expiry?
We would really appreciate this, thank you.
Yeah, it’s unfortunately more work than we can “allocate” on this plugin right now. We need to store each “dates” instead of just storing the “recurrence formula”. It’s planned, but no dates yet.
