أستخدم مساحة تخزين الكائنات minio لتخزين S3 الخاص بي وأحصل على هذا الخطأ:
rake aborted!
Aws::S3::Errors::Http504Error: Aws::S3::Errors::Http504Error (Aws::S3::Errors::Http504Error)
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/seahorse/client/plugins/raise_response_errors.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.143.0/lib/aws-sdk-s3/plugins/sse_cpk.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.143.0/lib/aws-sdk-s3/plugins/dualstack.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.143.0/lib/aws-sdk-s3/plugins/accelerate.rb:43:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/aws-sdk-core/plugins/checksum_algorithm.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/aws-sdk-core/plugins/jsonvalue_converter.rb:16:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/aws-sdk-core/plugins/idempotency_token.rb:19:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/aws-sdk-core/plugins/param_converter.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/seahorse/client/plugins/request_callback.rb:89:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/aws-sdk-core/plugins/response_paging.rb:12:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/seahorse/client/plugins/response_target.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/seahorse/client/request.rb:72:in `send_request'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.143.0/lib/aws-sdk-s3/client.rb:11285:in `list_objects_v2'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.143.0/lib/aws-sdk-s3/bucket.rb:1304:in `block (2 levels) in objects'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/aws-sdk-core/plugins/user_agent.rb:28:in `feature'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-s3-1.143.0/lib/aws-sdk-s3/bucket.rb:1303:in `block in objects'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/aws-sdk-core/resources/collection.rb:101:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/aws-sdk-core/resources/collection.rb:101:in `block in non_empty_batches'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/aws-sdk-core/resources/collection.rb:52:in `each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/aws-sdk-core/resources/collection.rb:52:in `block in each'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/aws-sdk-core-3.191.3/lib/aws-sdk-core/resources/collection.rb:58:in `each'
/var/www/discourse/lib/tasks/s3.rake:14:in `map'
/var/www/discourse/lib/tasks/s3.rake:14:in `existing_assets'
/var/www/discourse/lib/tasks/s3.rake:210:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rake-13.2.1/exe/rake:27:in `<top (required)>'
Tasks: TOP => s3:expire_missing_assets
I, [2024-11-11T08:02:51.942337 #1] INFO -- : Checking for stale S3 assets...
I, [2024-11-11T08:02:51.944197 #1] INFO -- : Terminating async processes
I, [2024-11-11T08:02:51.944334 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 39
I, [2024-11-11T08:02:51.944432 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 107
2024-11-11 08:02:51.944 UTC [39] LOG: received fast shutdown request
107:signal-handler (1731312171) Received SIGTERM scheduling shutdown...
2024-11-11 08:02:51.945 UTC [39] LOG: aborting any active transactions
2024-11-11 08:02:51.949 UTC [39] LOG: background worker "logical replication launcher" (PID 54) exited with exit code 1
2024-11-11 08:02:51.950 UTC [49] LOG: shutting down
107:M 11 Nov 2024 08:02:51.960 # User requested shutdown...
107:M 11 Nov 2024 08:02:51.960 * Saving the final RDB snapshot before exiting.
2024-11-11 08:02:52.047 UTC [39] LOG: database system is shut down
107:M 11 Nov 2024 08:02:52.207 * DB saved on disk
107:M 11 Nov 2024 08:02:52.208 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && sudo -E -u discourse bundle exec rake s3:expire_missing_assets failed with return #<Process::Status: pid 3550 exit 1>
exec failed with the params {"cd"=>"$home", "cmd"=>["sudo -E -u discourse bundle exec rake s3:upload_assets", "sudo -E -u discourse bundle exec rake s3:expire_missing_assets"]}
4f601885ffad64bcd29f6dbd06df1f0f86ad301341d40e752df7447809a32eff
خطأ أثناء حساب التقرير `storage_stats`: الطريقة غير المعرفة `start_with?' لـ nil
/var/www/discourse/app/models/site_setting.rb:172:in `use_dualstack_endpoint'
/var/www/discourse/lib/s3_helper.rb:269:in `s3_options'
لا. هذا هو الأمر، أنا متأكد. إنهم يستخدمون S3 للنسخ الاحتياطي، ولكن ليس للتحميلات، وهو إعداد شائع جدًا للمستضيفين الذاتيين. من السهل تكوين النسخ الاحتياطي لـ S3، ولا يتطلب شبكة توصيل محتوى (CDN) أو تغيير YML لتحميل الأصول المترجمة مسبقًا.
لدي نفس الشيء.. سجلت الدخول إلى مزود التخزين الخاص بي للتحقق مما إذا كنت قد دفعت الفاتورة، وقد فعلت ذلك.
لماذا تم دفع تغيير جذري كهذا دون أي إعلان؟
هل يُفترض بنا إدخال جميع التفاصيل في app.yml الآن؟
لماذا تمت إزالة جميع الإعدادات من الواجهة الخلفية للمسؤول؟ كيف يمكننا استرداد هذه الإعدادات؟ لقد قمت بإعداد هذا مرة واحدة منذ سنوات وليس لدي أي فكرة عن مفتاحي أو سري، ولست متأكدًا حتى مما إذا كان بإمكاني استرداد ذلك دون إعادة تعيين المفتاح (مما سيؤثر على الخدمات الأخرى التي أستخدم فيها نفس نقاط نهاية S3..).
لأنه لم يكن من المفترض أن يكسر أي شيء، ولكن رمز s3 لديه لدعم مجموعة كبيرة من الحالات الطرفية، وما لم تكتب هذا الرمز أو تنتبه إلى تطويره على مر السنين، فمن الصعب جدًا القفز ورؤية مدى ضخامة المشكلة حقًا.
