全新安装后,没有任何设置
discourse 3.4.0.beta3-dev 安装后日志报错:GeoLite2-City.mmdb 和 GeoLite2-ASN.mmdb
MaxMindDB (/var/www/discourse/vendor/data/GeoLite2-City.mmdb) 未找到:No such file or directory @ rb_sysopen - /var/www/discourse/vendor/data/GeoLite2-City.mmdb
下午 5:25
MaxMindDB (/var/www/discourse/vendor/data/GeoLite2-ASN.mmdb) 未找到:No such file or directory @ rb_sysopen - /var/www/discourse/vendor/data/GeoLite2-ASN.mmdb
下午 5:25
消息(报告了 2 份副本)
回溯
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:130:in `block in warn'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:231:in `block in dispatch'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:231:in `each'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:231:in `dispatch'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:130:in `warn'
/var/www/discourse/lib/discourse_ip_info.rb:88:in `rescue in mmdb_load'
/var/www/discourse/lib/discourse_ip_info.rb:84:in `mmdb_load'
/var/www/discourse/lib/discourse_ip_info.rb:14:in `open_db'
/var/www/discourse/lib/discourse_ip_info.rb:10:in `initialize'
/usr/local/lib/ruby/3.3.0/singleton.rb:124:in `new'
/usr/local/lib/ruby/3.3.0/singleton.rb:124:in `block in instance'
/usr/local/lib/ruby/3.3.0/singleton.rb:124:in `synchronize'
/usr/local/lib/ruby/3.3.0/singleton.rb:124:in `instance'
/var/www/discourse/lib/discourse_ip_info.rb:175:in `get'
/var/www/discourse/app/serializers/concerns/user_auth_tokens_mixin.rb:13:in `location'
(eval at active_model_serializers-0.8.4/lib/active_model/serializer.rb:467):5:in `_fast_attributes'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:468:in `rescue in attributes'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:455:in `attributes'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:89:in `block in _serializable_array'
activerecord-7.1.5/lib/active_record/relation/delegation.rb:100:in `each'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:79:in `map'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:79:in `_serializable_array'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:73:in `serializable_array'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:53:in `as_json'
activesupport-7.1.5/lib/active_support/json/encoding.rb:23:in `encode'
activesupport-7.1.5/lib/active_support/core_ext/object/json.rb:42:in `to_json'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:63:in `to_json'
multi_json-1.15.0/lib/multi_json/adapters/oj.rb:56:in `dump'
multi_json-1.15.0/lib/multi_json/adapter.rb:25:in `dump'
multi_json-1.15.0/lib/multi_json.rb:139:in `dump'
/var/www/discourse/app/controllers/application_controller.rb:759:in `json_result'
/var/www/discourse/app/controllers/users_controller.rb:258:in `update'
actionpack-7.1.5/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack-7.1.5/lib/abstract_controller/base.rb:224:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack-7.1.5/lib/abstract_controller/callbacks.rb:259:in `block in process_action'
activesupport-7.1.5/lib/active_support/callbacks.rb:121:in `block in run_callbacks'
/var/www/discourse/app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
i18n-1.14.6/lib/i18n.rb:353:in `with_locale'
/var/www/discourse/app/controllers/application_controller.rb:424:in `with_resolved_locale'
activesupport-7.1.5/lib/active_support/callbacks.rb:130:in `block in run_callbacks'
activesupport-7.1.5/lib/active_support/callbacks.rb:141:in `run_callbacks'
actionpack-7.1.5/lib/abstract_controller/callbacks.rb:258:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/rescue.rb:25:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/instrumentation.rb:74:in `block in process_action'
activesupport-7.1.5/lib/active_support/notifications.rb:206:in `block in instrument'
activesupport-7.1.5/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport-7.1.5/lib/active_support/notifications.rb:206:in `instrument'
actionpack-7.1.5/lib/action_controller/metal/instrumentation.rb:73:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/params_wrapper.rb:261:in `process_action'
activerecord-7.1.5/lib/active_record/railties/controller_runtime.rb:32:in `process_action'
actionpack-7.1.5/lib/abstract_controller/base.rb:160:in `process'
actionview-7.1.5/lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler-3.3.1/lib/mini_profiler/profiling_methods.rb:115:in `block in profile_method'
actionpack-7.1.5/lib/action_controller/metal.rb:227:in `dispatch'
actionpack-7.1.5/lib/action_controller/metal.rb:309:in `dispatch'
actionpack-7.1.5/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack-7.1.5/lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:51:in `block in serve'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:131:in `block in find_routes'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:124:in `each'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:124:in `find_routes'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-7.1.5/lib/action_dispatch/routing/route_set.rb:882:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack-2.2.10/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.10/lib/rack/conditional_get.rb:40:in `call'
rack-2.2.10/lib/rack/head.rb:12:in `call'
actionpack-7.1.5/lib/action_dispatch/http/permissions_policy.rb:36:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:399:in `call'
/var/www/discourse/lib/middleware/csp_script_nonce_injector.rb:12:in `call'
/var/www/discourse/config/initializers/008-rack-cors.rb:14:in `call'
rack-2.2.10/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.10/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/cookies.rb:689:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
activesupport-7.1.5/lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack-7.1.5/lib/action_dispatch/middleware/callbacks.rb:28:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
logster-2.20.0/lib/logster/middleware/reporter.rb:40:in `call'
/var/www/discourse/lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:35:in `call_app'
/var/www/discourse/lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:20:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/request_id.rb:28:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:24:in `call'
rack-2.2.10/lib/rack/method_override.rb:24:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/executor.rb:14:in `call'
rack-2.2.10/lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler-3.3.1/lib/mini_profiler.rb:334:in `call'
/var/www/discourse/lib/middleware/processing_request.rb:12:in `call'
message_bus-4.3.8/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:360:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/remote_ip.rb:92:in `call'
railties-7.1.5/lib/rails/engine.rb:536:in `call'
railties-7.1.5/lib/rails/railtie.rb:226:in `public_send'
railties-7.1.5/lib/rails/railtie.rb:226:in `method_missing'
rack-2.2.10/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.10/lib/rack/urlmap.rb:58:in `each'
rack-2.2.10/lib/rack/urlmap.rb:58:in `call'
unicorn-6.1.0/lib/unicorn/http_server.rb:634:in `process_client'
unicorn-6.1.0/lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn-6.1.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
环境
消息(报告了 2 份副本)
回溯
/var/www/discourse/lib/discourse_ip_info.rb:15:in `open_db'
环境
