Нужно найти способ заблокировать индексацию тем из категории
it is a fact that search engines, bots can index topics in a category on discourse. How to block Google, bing, yandex, … from indexing topics of a category?
We look forward to Discourse experts’ support.
1 лайк
You can change the category permission to TL0 so only logged in users will see it and also will block bots.
6 лайков
If that Don suggested works use it. It is the only 100% sure way. But if that forum must be open for random visitors you can’t use TL0. Sure you can use User-agent: * Disallow: / or similar meta, but sometimes those are respected and sometimes not. If somebody shares a link using gmail Google will index no matter you have in robots.txt or meta.
And those tricks are effective only if a bot obeys those. Most of SEO crawlers don’t follow. And then there is a zillion rogue bots and script kiddies trying to do something.
So, what you have to do depends on what kind level of privacy you are looking for.
4 лайка
