번역 및 라벨 올바른 표시 관련 도움
I’m trying to create a theme component that adds underlining to the composer toolbar.
I’m able to get it working, the button label is working, however when it’s used it returns
[en.composer.underline_text]
not the expected
Example Text
I’ve been going around in circles but unable to workout why, anyone got any idea what i’m missing?
Thanks
api-setup.js
import I18n from "I18n";
import { iconNode } from "discourse-common/lib/icon-library";
export default apiInitializer("0.11.1", (api) => {
  const currentLocale = I18n.currentLocale();
  I18n.translations[currentLocale].js.underline_button_title = settings.underline_button;
  I18n.translations[currentLocale].js.underline_text = settings.underline_text;
  api.onToolbarCreate((toolbar) => {
    const buttons = [
        group: "fontStyles",
        icon: "underline",
        shortcut: "U",
        title: "underline_button_title",
        perform: (e) => e.applySurround("[u]", "[/u]", "underline_text"),
    buttons.forEach((button) => toolbar.addButton(button));
  api.decorateCookedElement(
    async (elem, helper) => {
      const id = helper ? `post_${helper.getModel().id}` : "composer";
      applyHighlight(elem, id);
    { id: "wrap-mark" }
settings.yml
underline_button:
  default: "Underline"
  description:
    en: Enter the text for the title of the button in the composer.
underline_text:
  default: "Example Text"
  description:
    en: Enter the placeholder text that appears in the composer after the user clicks the button.
Svg_icons:
  type: 'list'
  list_type: 'compact'
  default: 'underline'
  description:
    en: "Include FontAwesome 6 icon classes for each icon used in the list."
en.yml
en:
  js:
    underline_button_title: settings.underline_button
    underline_text: settings.underline_text
Why do you create the texts as settings instead of putting them directly in en.yml?
I think Composer Footnote Button is a helpful example
Thanks for pointing me in the right direction
Turned out
should be
I18n.translations[currentLocale].js.composer.underline_text = settings.underline_text;
