Кнопка регистрации не отображается на некоторых страницах с Discourse для форумов (мой пример: gimkit creative forums)
So I was trying to look up if something was possible to do. I needed to sign up, but the sign up option did not exist for some reason. I tried to log in, but it also did not work, even though I had a discourse account and a gimkit account. Anybody know the reason why?
Could you send a screenshot of what you’re seeing?
Thanks.
And logging into your existing account doesn’t work, correct?
yes, it does not work.
I don’t think it’s a bug. There is a setting admins can use to allow only users that were invited to sign up.
Or a similar setting like
Such settings are the reason why it is more helpful to contact the admin of a forum if you have a problem with a specific forum.
2 лайка
something similar: https://meta.discourse.org/t/getting-the-signup-button/257535/7
ok, thanks for the help.
Could it also be that allow new registrations is turned off?
1 лайк
