Error de OAuth - No se puede determinar la causa exacta de este error
Recibimos este error de OAuth y al refrescar la página funciona… Revisé el registro de errores y aquí están los detalles:::
Faraday::TimeoutError (Timeout::Error)
Recibo el siguiente registro de rastreo de errores:
activesupport-7.2.2/lib/active_support/broadcast_logger.rb:130:in `block in warn'
activesupport-7.2.2/lib/active_support/broadcast_logger.rb:231:in `block in dispatch'
activesupport-7.2.2/lib/active_support/broadcast_logger.rb:231:in `each'
activesupport-7.2.2/lib/active_support/broadcast_logger.rb:231:in `dispatch'
activesupport-7.2.2/lib/active_support/broadcast_logger.rb:130:in `warn'
/usr/local/lib/ruby/3.3.0/forwardable.rb:240:in `warn'
/var/www/discourse/plugins/discourse-oauth2-basic/lib/oauth2_faraday_formatter.rb:7:in `request'
faraday-2.12.1/lib/faraday/response/logger.rb:22:in `call'
faraday-2.12.1/lib/faraday/rack_builder.rb:152:in `build_response'
faraday-2.12.1/lib/faraday/connection.rb:452:in `run_request'
oauth2-1.4.11/lib/oauth2/client.rb:107:in `request'
oauth2-1.4.11/lib/oauth2/client.rb:177:in `get_token'
oauth2-1.4.11/lib/oauth2/strategy/auth_code.rb:32:in `get_token'
omniauth-oauth2-1.7.3/lib/omniauth/strategies/oauth2.rb:126:in `build_access_token'
omniauth-oauth2-1.7.3/lib/omniauth/strategies/oauth2.rb:91:in `callback_phase'
omniauth-1.9.2/lib/omniauth/strategy.rb:238:in `callback_call'
omniauth-1.9.2/lib/omniauth/strategy.rb:189:in `call!'
omniauth-1.9.2/lib/omniauth/strategy.rb:169:in `call'
omniauth-1.9.2/lib/omniauth/builder.rb:45:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:43:in `call'
rack-2.2.10/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.10/lib/rack/conditional_get.rb:27:in `call'
rack-2.2.10/lib/rack/head.rb:12:in `call'
actionpack-7.2.2/lib/action_dispatch/http/permissions_policy.rb:38:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:397:in `call'
/var/www/discourse/lib/middleware/csp_script_nonce_injector.rb:12:in `call'
/var/www/discourse/config/initializers/008-rack-cors.rb:14:in `call'
rack-2.2.10/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.10/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/callbacks.rb:31:in `block in call'
activesupport-7.2.2/lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack-7.2.2/lib/action_dispatch/middleware/callbacks.rb:30:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/debug_exceptions.rb:31:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/show_exceptions.rb:32:in `call'
logster-2.20.0/lib/logster/middleware/reporter.rb:40:in `call'
railties-7.2.2/lib/rails/rack/logger.rb:41:in `call_app'
railties-7.2.2/lib/rails/rack/logger.rb:29:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:20:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/request_id.rb:33:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:24:in `call'
rack-2.2.10/lib/rack/method_override.rb:24:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/executor.rb:16:in `call'
rack-2.2.10/lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler-3.3.1/lib/mini_profiler.rb:191:in `call'
/var/www/discourse/lib/middleware/processing_request.rb:12:in `call'
message_bus-4.3.8/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:360:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/remote_ip.rb:96:in `call'
railties-7.2.2/lib/rails/engine.rb:535:in `call'
railties-7.2.2/lib/rails/railtie.rb:226:in `public_send'
railties-7.2.2/lib/rails/railtie.rb:226:in `method_missing'
rack-2.2.10/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.10/lib/rack/urlmap.rb:58:in `each'
rack-2.2.10/lib/rack/urlmap.rb:58:in `call'
unicorn-6.1.0/lib/unicorn/http_server.rb:634:in `process_client'
unicorn-6.1.0/lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn-6.1.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
Aquí están la configuración de oAuth2 ::
Hola, formatea el error entre triples comillas invertidas (```).
error message here
2 Me gusta
@Steve_John He formateado tu publicación para incluir los registros en bloques de código ```. En el futuro, te recomiendo que pongas errores o código usando lo que Nate sugirió anteriormente.
Dado que se trata de un problema de formato de faraday y te estás autenticando correctamente al actualizar, te sugiero que desactives esta configuración: oauth2_debug_auth y no deberías volver a ver el error.
1 me gusta
Claro, Natalie. Seguiré tus sugerencias y gracias por actualizarlas.
Aquí están la configuración actual, supongo que está pidiendo deshabilitar esta configuración. ::
Intenté deshabilitar estas opciones y volver a probar, de 5 intentos de volver a iniciar sesión… un intento volvió a dar el mismo error, este problema no lo solucionó por completo.
Mirándolo de nuevo, la configuración oauth2_debug_auth probablemente entra en vigor cuando se inicia el servidor, ya que el middleware oauth y el registrador para depuración se adjuntan en ese momento.
def register_middleware(omniauth)
  omniauth.provider :oauth2_basic,
      opts[:client_options][:connection_build] = lambda do |builder|
        if SiteSetting.oauth2_debug_auth && defined?(OAuth2FaradayFormatter)
          builder.response :logger,
                         Rails.logger,
                         { bodies: true, formatter: OAuth2FaradayFormatter }
La mayoría de las configuraciones del sitio no requieren un reinicio, pero necesitará reiniciar su servidor para que esta configuración en particular surta efecto.
Dicho esto, el problema subyacente real es Faraday::TimeoutError (Timeout::Error), de todos modos. No creo que mi sugerencia de desactivar los registros solucione su problema. Probablemente tendrá que verificar si hay algún problema de red entre su instancia de Discourse y el proveedor OAuth2.
