TypeError: Не удалось установить свойство deleteTopic объекта [object Object], у которого есть только геттер
I have a long standing installation of Discourse that seems to be getting js errors.
Uncaught (in promise) TypeError: Cannot set property deleteTopic of [object Object] which has only a getter
    at ye (index.js:1641:1)
    at y (mixin.js:281:1)
    at w.apply (mixin.js:482:1)
    at e.proto (core.js:600:1)
    at new y (core.js:91:1)
    at new e (core.js:371:1)
    at e.create (core.js:385:1)
    at h.create (index.js:385:1)
    at index.js:287:1
    at index.js:230:1
    at i.lookup (index.js:125:1)
    at u.lookup (container_proxy.js:19:1)
    at m.s (index.js:2075:1)
    at index.js:1310:1
    at validator.js:635:1
    at pe.get (index.js:1309:1)
    at m.r [as topic] (index.js:881:1)
    at Te (index.js:1682:1)
    at reference.js:164:1
    at reference.js:125:1
    at validator.js:622:1
    at d (reference.js:124:1)
    at reference.js:162:1
    at De (index.js:1806:1)
    at ze.create (index.js:1974:1)
    at Object.evaluate (runtime.js:2676:1)
    at Object.evaluate (runtime.js:1052:1)
    at It.evaluateSyscall (runtime.js:4204:1)
    at It.evaluateInner (runtime.js:4175:1)
    at It.evaluateOuter (runtime.js:4168:1)
    at Wt.next (runtime.js:4999:1)
    at Wt._execute (runtime.js:4986:1)
    at Wt.execute (runtime.js:4979:1)
    at Qt.sync (runtime.js:5046:1)
    at hr.<anonymous> (index.js:4672:1)
    at index.js:4934:1
    at Nt (runtime.js:4080:1)
    at gr._renderRoots (index.js:4916:1)
    at gr._renderRootsTransaction (index.js:4960:1)
    at gr._renderRoot (index.js:4905:1)
    at gr._appendDefinition (index.js:4830:1)
    at gr.appendOutletView (index.js:4820:1)
    at invoke (backburner.js.js:282:1)
    at h.flush (backburner.js.js:197:1)
    at p.flush (backburner.js.js:358:1)
    at B._end (backburner.js.js:798:1)
    at backburner.js.js:523:1
application.js:155 TypeError: r.subscribe is not a function
    at d.setupController (topic-from-params.js:94:21)
    at d.setup (route.js:444:1)
    at o (router_js.js:1544:1)
    at s.routeEnteredOrUpdated (router_js.js:1554:1)
    at s.setupContexts (router_js.js:1500:1)
    at s.finalizeTransition (router_js.js:1408:1)
    at router_js.js:1347:1
    at _ (rsvp.js:434:1)
    at y (rsvp.js:420:1)
error @ application.js:155
router.js:1141 Error while processing route: topic.fromParamsNear r.subscribe is not a function
I have a cascading set of js errors as a result. When I go to a particular topic, it just shows the error, something went wrong, screen.
Any suggestions on troubleshooting? Thanks in advance.
1 лайк
Hi @etc :wave: did you check safe mode yet?
when you say “long standing” - I assume you mean longtime functional; but has it been updated to latest version recently?
3 лайка
I’ll check out safe mode, thanks.
Yes, long standing as in it’s been functional for years. I was on 3.1, then I posted a reply and then started running into the errors. I upgraded to the latest version just to see if it would fix, but even though the update worked properly, the issue persists.
Thanks for the link, it is helping me narrow it down.
So, the option Disable all client-side plugin customizations ended up fixing it. Do you have some documentation on what precisely that is referring to? Thank you! <3 Happy New Year, btw
1 лайк
So, we’re pretty light on plugins, but it looks like it’s the Discourse-Encrypt plugin, which I believe is an official plugin. When I disable it, everything works, once I reenable it, everything goes down again. Not sure why this would happen out of nowhere.
1 лайк
This plugin is deprecated, you may want to uninstall it read the topic for instructions.
2 лайка
I’ll go ahead and uninstall it. I wonder if something flipped as of Jan 1 that would break the plugin. It seemed to have happened out of nowhere. Thanks so much! Happy New Year!
2 лайка
