2つの追跡変数が更新されない
以下のコードがあります。
import Component from "@glimmer/component";
import { tracked } from '@glimmer/tracking';
import { action } from '@ember/object';
import { inject as service } from "@ember/service";
import { defaultHomepage } from "discourse/lib/utilities";
const xhr = new XMLHttpRequest();
xhr.open("GET", "/cakeday/anniversaries/today.json");
xhr.send();
xhr.responseType = "json";
xhr.onload = () => {
    if (xhr.readyState == 4 && xhr.status == 200) {
        let resp = xhr.response;
        let numberOfAnns = resp['total_rows_anniversaires'];
        let allAnns = resp['anniversaries']; // Is a list of dicts
        console.log(allAnns);
        let allAnnsUsernames = [];
        for (var annUserdata in allAnns) {
            console.log(allAnns[annUserdata]['username']);
            allAnnsUsernames.push(allAnns[annUserdata]['username']);
        var annsOfData = {'num_anns': numberOfAnns, 'anns_users': allAnnsUsernames};
return annsOfData;
export default apiInitializer("1.14.0", (api) => {
    //const banner_location = settings.banner_location
    api.renderInOutlet(
        settings.banner_location,
        class BdaysAnnsBanner extends Component {
            @tracked annsDataFinal = null;
            @tracked bdaysDataFinal = null;
            @tracked areBothBannersVisible = true;
            @tracked isAnnsVisible = null;
            @tracked isBdaysVisible = null;
            @service router;
            constructor() {
                super(...arguments);
                this.fetchAnnsData(); // Automatically fetch on initialization
                this.fetchBdaysData();
            // Asynchronously fetch the data and update tracked property
            @action
            async fetchAnnsData() {
                const response = await fetch("/cakeday/anniversaries/today.json");
                const json = await response.json();
                let numberOfAnns = parseInt(json['total_rows_anniversaries']);
                let allAnns = json['anniversaries']; // Is a list of dicts
                for (let annUserdata of allAnns) {
                    allAnnsUsernames.push(annUserdata['username']);
                this.annsDataFinal = {'num_anns': numberOfAnns, 'anns_users': allAnnsUsernames, 'visible': true, 'isFilled': true};
                this.updateBothBannersVisibility(this.annsDataFinal);
            @action
            async fetchBdaysData() {
                 // Declare bdaysDataFinal here
                let bdaysDataFinal;
                // Fetch birthdays data
                const response = await fetch("/cakeday/birthdays/today.json");
                // Run the logic to process the data
                let numberOfBdays = parseInt(json['total_rows_birthdays']);
                let allBdays = json['birthdays']; // Is a list of dicts
                let allBdaysUsernames = [];
                for (let bdayUserdata of allBdays) {
                    allBdaysUsernames.push(bdayUserdata['username']);
                this.bdaysDataFinal = {'num_bdays': numberOfBdays, 'bdays_users': allBdaysUsernames, 'visible': true, 'isFilled': true};
                this.updateBothBannersVisibility(this.bdaysDataFinal);
                //console.log(annsDataFinal);  // Just to verify the result
            @action
            updateBothBannersVisibility(bannerData) {
                console.log(bannerData.num_anns);
                // Check if it's anns or bdays
                if (bannerData.num_anns) { // It's anns
                    console.log('Anns:')
                    if (bannerData.num_anns == 0 && settings.hide_unused_data) {
                        console.log(`Anns+setting: ${bannerData.num_anns == 0 && settings.hide_unused_data}`);
                        this.isAnnsVisible = false;
                        console.log(`isAnnsV: ${this.isAnnsVisible}`);
                        //console.log(this.isBdaysVisible);
                } else { // It's bdays
                    console.log(bannerData.num_bdays);
                    if (bannerData.num_bdays == 0 && settings.hide_unused_data) {
                        console.log(`Bdays+setting: ${bannerData.num_bdays == 0 && settings.hide_unused_data}`);
                        this.isBdaysVisible = false;
                        console.log(`isBdaysV: ${this.isBdaysVisible}`);
                        //console.log(this.isAnnsVisible);
                // Uses an inequality. If not the same (true), banner is shown. If it is the same, inequality is not satisfied, and the banner will be hidden.
                this.areBothBannersVisible = !(this.isAnnsVisible === false && this.isBdaysVisible === false); // Or: this.areBothBannersVisible = this.isAnnsVisible || this.isBdaysVisible;
                console.log(this.areBothBannersVisible);
            // Getter for the data
            get annsData() {
                //return this.annsDataFinal;
                if (this.annsDataFinal !== null) {
                    if (this.annsDataFinal.num_anns == 0) {
                        if (settings.hide_unused_data) {
                            this.annsDataFinal.isFilled = false;
                            this.annsDataFinal.visible = false;
                        } else {
                    } else {
                        this.annsDataFinal.isFilled = true;
                        this.annsDataFinal.visible = true;
                    //this.updateBothBannersVisibility(this.annsDataFinal);
                    // If the data is not loaded yet, return null or any default value
            get bdaysData() {
                //return this.bdaysDataFinal;
                if (this.bdaysDataFinal !== null) {
                    if (this.bdaysDataFinal.num_bdays == 0) {
                            this.bdaysDataFinal.isFilled = false;
                            this.bdaysDataFinal.visible = false;
                        } else {
                            this.bdaysDataFinal.visible = true;
                    } else {
                        this.bdaysDataFinal.isFilled = true;
                    //this.updateBothBannersVisibility(this.bdaysDataFinal);
            get isHomepage() {
                const { currentRouteName } = this.router;
                return currentRouteName === `discovery.${defaultHomepage()}`;
            //console.log(this.areBothBannersVisible);
            <template>
                {{#if this.areBothBannersVisible}}
                    {{#if this.isHomepage}}
                        <div class='bdaysannsbanner' id='bdaysannsbanner'>
                            {{#if this.annsData.visible}}
                                <div class='anns'>
                                    {{#if this.annsData.isFilled}}
                                        <p>{{this.annsData.num_anns}} users are celebrating their anniversary!</p>
                                        <!-- Display the anniversaries data -->
                                        {{#each this.annsData.anns_users as |username|}}
                                            <span><a class='mention'>{{username}}</a></span>
                                        {{/each}}
                                    {{else}}
                                        <p>No one has their anniversary today!</p>
                                    {{/if}}
                                </div>
                            {{/if}}
                            <br />
                            {{#if this.bdaysData.visible}}
                                <div class='bdays'>
                                    {{#if this.bdaysData.isFilled}}
                                        <p>{{this.bdaysData.num_bdays}} users are celebrating their birthday!</p>
                                        <!-- Display the birthday data -->
                                        {{#each this.bdaysData.bdays_users as |username|}}
                                        {{/each}}
                                    {{else}}
                                        <p>No one is celebrating their birthday today!</p>
                                    {{/if}}
                                </div>
                            {{/if}}
                        </div>
                    {{/if}}
                {{/if}}
            </template>
これらの変数が更新されないのは奇妙です。正しく使用されていないのでしょうか?
申し訳ありません、これを再度取り上げますが、なぜこれが起こっているのかまだわかりません。
私の現在のコード:
import { ajax } from "discourse/lib/ajax";
import { getOwner } from '@ember/application';
    api.renderInOutlet(
            @service router;
            constructor() {
            @action
                console.log(json);
            @action
                let bdaysDataFinal;
            @action
            get annsData() {
                        } else {
                    } else {
            get bdaysData() {
                            console.log(`this.isAnnsVisible: ${this.isAnnsVisible}`);
                            console.log(`this.isBdaysVisible: ${this.isBdaysVisible}`);
                        } else {
                    } else {
            get isHomepage() {
            <template>
                                <div class='anns'>
                                        {{/each}}
                                    {{else}}
                                    {{/if}}
                                </div>
                            {{/if}}
                            <br />
                                <div class='bdays'>
                                        {{/each}}
                                    {{else}}
                                    {{/if}}
                                </div>
                            {{/if}}
                        </div>
                    {{/if}}
                {{/if}}
            </template>
私のリポジトリ:
まだ正確にはわかりませんが…
この await は不要です。
response はすでにオブジェクトになっているはずなので、.json() などが必要な理由がわかりません。おそらくこれを大幅に簡略化できるでしょう。
これは渡す必要はありません。追跡対象の変数はコンポーネント全体でスコープ内にあるため、呼び出すだけで、アクションで参照できます。
いくつかのスタイルに関するヒントです。
  • 共有コードを console.log で覆い尽くさないでください。そうすると、木を見て森を見失うことになります。
  • 4スペースではなく2スペースのインデントを使用してください。これは Discourse の標準です。テンプレートを参照してください。
  • これを専用の .gjs ファイルに移動することを検討してください。
  • GitHub の番号をクリックすると、共有可能なリンクを取得でき、必要に応じてコードをプレビューできます。
高度な設定:
  • Prettier と ESlint を設定してください。前者はスタイル用、後者はスタイルとバグの検出に役立ちます。
これではないですよね?
そこまでしなくてもいいですが、それも一つの方法です。
まずは手動で行うだけでも十分です。
これはおそらく機能しないでしょう。
EmberJSはネストされたプロパティを監視しないと思います。
プロパティは同じレベルで作成、追跡、テストする必要があります。
したがって、annsDataVisibleという名前の追跡されたプロパティを作成し、その値を更新して、ifステートメントで使用してください。
値の子属性だけでなく、オブジェクト全体を再割り当てすることもできます。これにより、再描画がトリガーされる可能性があります。
