Plugin de Tradução: NotPreloadedError
Olá,
Estou usando o plugin de tradução com LibreTranslate no Bonn.Community. Ele funciona em certos artigos, outros me deram esta mensagem de erro.
Tentei reconstruir, mas isso não ajudou.
HasCustomFields::NotPreloadedError (Tentativa de acessar o campo personalizado não pré-carregado 'post_detected_lang' na classe 'Post'. Isso é proibido para evitar consultas N+1.) app/models/concerns/has_cus
app/models/concerns/has_custom_fields.rb:235:in `[]'
plugins/discourse-translator/lib/discourse_translator/guardian_extension.rb:30:in `can_translate?'
plugins/discourse-translator/plugin.rb:47:in `block (2 levels) in activate!'
(eval at /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:467):108:in `_fast_attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:456:in `attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:347:in `as_json'
app/serializers/post_stream_serializer_mixin.rb:67:in `block in posts'
activerecord (7.2.2.1) lib/active_record/relation/delegation.rb:98:in `each'
app/serializers/post_stream_serializer_mixin.rb:60:in `map'
app/serializers/post_stream_serializer_mixin.rb:60:in `posts'
app/serializers/post_stream_serializer_mixin.rb:31:in `post_stream'
(eval at /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/active_model_serializers-0.8.4/lib/active_model/serializer.rb:467):3:in `_fast_attributes'
activesupport (7.2.2.1) lib/active_support/json/encoding.rb:23:in `encode'
activesupport (7.2.2.1) lib/active_support/core_ext/object/json.rb:42:in `to_json'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:331:in `to_json'
multi_json (1.15.0) lib/multi_json/adapters/oj.rb:56:in `dump'
multi_json (1.15.0) lib/multi_json/adapter.rb:25:in `dump'
multi_json (1.15.0) lib/multi_json.rb:139:in `dump'
app/controllers/application_controller.rb:528:in `render_json_dump'
app/controllers/topics_controller.rb:1385:in `block (2 levels) in perform_show_response'
actionpack (7.2.2.1) lib/action_controller/metal/mime_responds.rb:224:in `respond_to'
app/controllers/topics_controller.rb:1375:in `perform_show_response'
app/controllers/topics_controller.rb:191:in `show'
actionpack (7.2.2.1) lib/action_controller/metal/basic_implicit_render.rb:8:in `send_action'
actionpack (7.2.2.1) lib/abstract_controller/base.rb:226:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/rendering.rb:193:in `process_action'
actionpack (7.2.2.1) lib/abstract_controller/callbacks.rb:261:in `block in process_action'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:121:in `block in run_callbacks'
app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
i18n (1.14.6) lib/i18n.rb:353:in `with_locale'
app/controllers/application_controller.rb:424:in `with_resolved_locale'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:130:in `block in run_callbacks'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:141:in `run_callbacks'
actionpack (7.2.2.1) lib/abstract_controller/callbacks.rb:260:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/rescue.rb:27:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/instrumentation.rb:77:in `block in process_action'
activesupport (7.2.2.1) lib/active_support/notifications.rb:210:in `block in instrument'
activesupport (7.2.2.1) lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport (7.2.2.1) lib/active_support/notifications.rb:210:in `instrument'
actionpack (7.2.2.1) lib/action_controller/metal/instrumentation.rb:76:in `process_action'
actionpack (7.2.2.1) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.2.2.1) lib/active_record/railties/controller_runtime.rb:39:in `process_action'
actionpack (7.2.2.1) lib/abstract_controller/base.rb:163:in `process'
actionview (7.2.2.1) lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:115:in `block in profile_method'
actionpack (7.2.2.1) lib/action_controller/metal.rb:252:in `dispatch'
actionpack (7.2.2.1) lib/action_controller/metal.rb:335:in `dispatch'
actionpack (7.2.2.1) lib/action_dispatch/routing/route_set.rb:67:in `dispatch'
actionpack (7.2.2.1) lib/action_dispatch/routing/route_set.rb:50:in `serve'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:53:in `block in serve'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:133:in `block in find_routes'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:126:in `each'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:126:in `find_routes'
actionpack (7.2.2.1) lib/action_dispatch/journey/router.rb:34:in `serve'
actionpack (7.2.2.1) lib/action_dispatch/routing/route_set.rb:896:in `call'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack (2.2.10) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.10) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.10) lib/rack/head.rb:12:in `call'
actionpack (7.2.2.1) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
lib/middleware/anonymous_cache.rb:403:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:26:in `call'
rack (2.2.10) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.10) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/callbacks.rb:31:in `block in call'
activesupport (7.2.2.1) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (7.2.2.1) lib/action_dispatch/middleware/callbacks.rb:30:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/debug_exceptions.rb:31:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/show_exceptions.rb:32:in `call'
logster (2.20.0) lib/logster/middleware/reporter.rb:40:in `call'
railties (7.2.2.1) lib/rails/rack/logger.rb:41:in `call_app'
railties (7.2.2.1) lib/rails/rack/logger.rb:29:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/request_id.rb:33:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
rack (2.2.10) lib/rack/method_override.rb:24:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/executor.rb:16:in `call'
rack (2.2.10) lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:334:in `call'
lib/middleware/processing_request.rb:12:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
lib/middleware/request_tracker.rb:385:in `call'
actionpack (7.2.2.1) lib/action_dispatch/middleware/remote_ip.rb:96:in `call'
railties (7.2.2.1) lib/rails/engine.rb:535:in `call'
railties (7.2.2.1) lib/rails/railtie.rb:226:in `public_send'
railties (7.2.2.1) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.10) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.10) lib/rack/urlmap.rb:58:in `each'
rack (2.2.10) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
info backtrace env
1 Curtiu
@nat trabalhou recentemente no plugin, me pergunto se isso está relacionado, vamos dar uma olhada.
Este problema é novo, funcionava bem anteriormente?
2 Curtiram
Você pode compartilhar em qual versão do plugin você está? Você deve ser capaz de ver o sha na página /admin/plugins do seu site, por exemplo, 97edd7d na captura de tela abaixo.
Não posso dizer, pois não estávamos usando ativamente o plugin por um tempo.
Descobri isso quando estava brincando com o plugin ActivityPub.
0.3.0, 97edd7d
1 Curtiu
Este erro deve ser corrigido com a nova atualização - Nós nos afastamos dos campos personalizados e agora estamos usando tabelas para traduções.
1 Curtiu
Este tópico foi fechado automaticamente após 3 dias. Novas respostas não são mais permitidas.
