AI로 코드 포맷팅을 위한 모더레이션 도구
OpenAI forum is struggling with the volume of users who don’t format their code. One of the community’s Regulars has raised this in the Lounge.
7개의 좋아요
There is already possibility to publish AI explains, change times, proofread… sure, none of those happens exacly right on published text, but still. This is just a modification of same principle :smirking_face:
A plugin that allows a group to add three ticks before and after chosen area.
4개의 좋아요
I would have a crack at this myself, but it’s hosted.
2개의 좋아요
Yeah… no happiness to install plugins.
2개의 좋아요
We could make an automation that just does this
Something like if you have 8/10 confidence that source code needs formatting, just format it
There is also the theme component that asks people to format code which we could install
7개의 좋아요
We have a lot of people that seem to be new to coding in general, and some of them make a good effort.
Sometimes it’s little things, like the user forgetting (or not knowing how to) set the language
<hello>
<hello>
sometimes they paste code that contains backticks that end up not escaping properly, so they just give up I suppose (I couldn’t find the example I was thinking of rn)
In these cases, it’s probably not super helpful, and IMO onboarding new users should be as easy as possible (it’s likely already overwhelming as it is)
The idea of giving senior users a button would be to control inference cost/usage with a more powerful model if that’s an issue or concern.
Anyways, thanks for considering this!
5개의 좋아요
An interesting thing we could quite easily do is allow certain groups access to certain “AI Helper” features on posts.
Then we could add an “AI Helper” task here and unlock it to TL3 on your forum.
This can work quite well, downside though is that it has to generate a lot of tokens so it can be extremely slow.
Ideally we would need to teach helper to trade in “diffs” so it can generate significantly less tokens in cases where there is a lot of source.
5개의 좋아요
Well. OpenAI have “Predicted Outputs” feature which would be perfect for this use case, I believe:
(I suspect this is how their Canvas tooling works)
I appreciate that may be somewhat OpenAI specific atm, but no doubt others will follow.
3개의 좋아요
Not quite, I tested it out and it is expensive and is certainly not perfect:
I would say a “diff” based approach probably has the most chance of working.
Something like this may work (JSON output looking for markers) Crafting Concise Prompts for Markdown Formatting - AI Conversation - Discourse Meta
5개의 좋아요
That’s unfortunate. I see you’ve shared your feedback with OpenAI :+1:. Definitely seems like an immature feature that is not yet living up to billing (ahem)
1개의 좋아요
We could swing something like this with persona triage and a custom tool
Persona triage (gpt 4o mini) → custom tool → llm to fix (gpt 4o) → api to submit edit
The challenge though is how comfortable are we allowing the llm to apply the edit with zero hallucinations?
A possibility could be having the llm to fix call return 2 line numbers (where code starts and where it ends) and then use that information to add backticks, that way there is a lot less risk of destruction.
Will have a further think about this, but I do think something is workable here.
1개의 좋아요
