Automatische vertaling, hoe uit te schakelen?
Hi, I can see this morning that my posts here are automatically translated to French, any way to disable that (my preferred language in my preferences is English), thanks.
Here on Meta?
We are translating every post into a dozen languages and show the user’s preferred locale version.
If you selected English in your preferences and are still seeing everything in French here, you may have a sticky override on your cookies. Try using the locale selector on the header to overwrite it, or if that doesn’t work, clean the locale cookie.
Ok thanks, I tried to clear my Discourse cookie and my posts are now in English.
Where in preferences do I set English?
Ah the Interface tab under Prefrences
Is that a browser setting?
