BBCode Plugin BBCode tags don't work any more
Our current version is 3.5.0.beta9-dev.
Topics with BBCode tags that already exist show fine.
But when I try to use a color tag in a new topic, it shows in the text and does not change the color. Also, anchor tags wouldn’t work.
The installed plugin looks like this:
It seems that I can’t update it manually - is it not supported any more?
Thank you for hints.
Edit: Okay I found a way. If you first switch the editor and start writing THEN, then the codes are interpreted correctly.
As an admin, you can configure the default composer for your community using the Default composition mode site setting. It may make sense for your forum to stick with Markdown as the default for now if users use BBCode tags frequently.
